Results 1 to 5 of 5
    Sep 2009
    Meron po ako lancer 92. malakas na siya sa gas, ang suggestion ay ipalinis ko na daw yung carborador. Nagdadalawang isip lang po ako na pabuksan, baka magkadeprensya lalo.. Baka may advice po kayo?? Salamat
    May 2007
    If the diagnosis say's you needed it, then youll need to take apart. If in doubt, then dont.
    You dont have any other choice if experiencing these.
    If it needs cleaning it'll be because one of the "jets" (orofices which control the amount of fuel added) has become obstructed. -low power runs unevenly at certain throttle openings, white blistery deposits on spark plugs. Or there may be blockage in some other passage.
    Or the float may be leaking, needle and seat damaged (overfilling with fuel, black smoke, runs roughly).
    Or use a Gumout Carburator Cleaner. Easy to use just follow the can direction.
    Oh!!!! one more thing your car need a tune up and check tire for proper air. All those can contribute a gas guzzler.
    Feb 2009
    Quote Originally Posted by erryl View Post
    erryl,
    mikuni carbuertors if not tampered with and not damaged from mishandling should be okay. they just need periodic cleaning both the external exposed linkages and vents and also the main and the auxulliary venturii using the pressurized lacquer thinner in a can or carburetor cleaner. low gas mileage could also be caused by improper tire pressures, wrong type of tires, dragging brakes, dragging driveline, clogged air filter, too thick of motor oil used, bad ignition, excessive dead weight in the car as in "emergency tools and supplies", overcooled engine or jack rabbit driving habits.
    jick
    Oct 2005
    Patanong din po about carburetor. Ksai namamatay po ang engine ko kapag paakyat ang takbo parang nauubusan ng gasolina ang carb. Marami na po ako napagawa tulad ng palit ng fuel pump, air and fuel filter, spark plugs at pinalinis ko na rin ang carb ko sa kamuning. Ano pa po kaya possible na sira?
    May 2007
    Hmmm! You have done most of the possible cause. Have you been check the pressure regulator lately? Pressure regulator is inserted in the fuel line just before the carburator.
    Although I believe those are the most common problem but, Catalytic converters are possible too. Most people never think to replace them. If the engine cant breath it wont run well. Try bypassing the cat, drive up-hill if it works properly you just found the cause..replace it.
Doubts on Carburetor overhaul
