erryl,
mikuni carbuertors if not tampered with and not damaged from mishandling should be okay. they just need periodic cleaning both the external exposed linkages and vents and also the main and the auxulliary venturii using the pressurized lacquer thinner in a can or carburetor cleaner. low gas mileage could also be caused by improper tire pressures, wrong type of tires, dragging brakes, dragging driveline, clogged air filter, too thick of motor oil used, bad ignition, excessive dead weight in the car as in "emergency tools and supplies", overcooled engine or jack rabbit driving habits.
jick
