You will only get a slight EGT temp rise around 10C, basically insignificant if your doing it properly. This is also not for for gas engines it's for diesels.
You don't need water injection to run LPG fumigation. The best way i can describe LPG fumigation is a Chip in a bottle, it increases injection timing while adding fuel. It due to it's low cetane number allows you to burn a up to 98% of your diesel. Adding water injection will just let you make more power and turn up the LPG. But really with 3psi you will be very happy on a 4cly turbo diesel.
Anyone interested in a system can PM me, I can do a few this trip. Just like the water injection your guaranteed results. A progressive system is really the best way to go but you do a normal boost activated set up. Currently mine is just boost activated but will be switching to progressive.
