Page 388 of 659 FirstFirst ... 288338378384385386387388389390391392398438488 ... LastLast
Results 3,871 to 3,880 of 6585
    #3871
    Quote Originally Posted by trucker111 View Post
    I think that's the right adjective... magaspang ang takbo.
    nakakainis din kasi lumakas ang vibration.
    4850kms to go
    malamang mga 3000kms palit na.
    will probably try zic x7 10w30 next unless somebody will give negative feedback on this
    Sir, i have the same oil for my upcoming change oil this coming weekend. first time to try these formulation of zic. Dati Zic RV ako and Top 1 SDO. I believe your ride is a TCI starex?
    Jul 2013
    #3872
    My Innova currently have Delo Gold in it.
    Coming from Toyota Fully Synthetic, I'd say it is good in its first 1000kms.
    I have to see if it will maintain its performance until the next oil change (after 3,500kms or 4 months). Yes, I am experimenting on 3 oil changes in one year (instead to two) using mineral oil.
    Quote Originally Posted by Lew_Alcindor View Post
    Please keep all receipts also an excel file hehehe. Its tedious but well worth the information and good when its time to sell the vehicle.
    Jul 2013
    #3874
    I already have a record book. I just need to write the necessary stuff. I did it with my old corolla.
    Mar 2015
    #3875
    Quote Originally Posted by amoyligo View Post
    Sabi ko sa inyo overrated ang delo oil. Ginamit ko yan sa 12 rent a car montero. Pati sa taxi ng family business at ng relatives. Ilan beses namin inulit dahil mura din bigay pero wala talaga ang gaspang ng takbo. Same with shell gaspang na pigil takbo.
    So its better to try the oil and compare.
    Sir since you have quite an experience with oils could you recommend what oil can i try with my ride po? I am now using shell helix 5w/40 in my car. What other brands can you recommend po that is better for gas fed engines sir? Thank you [emoji4]
    Jul 2015
    #3876
    Business kasi kami kaya factor lowest price, current ratings.
    Ngayon sa business we alternate valvoline, zic, castrol. Subok na namin.
    For our personal car gamit ko for gasoline engine zic a+, castrol edge, synpower. Pag pumunta pinsan ko sa america sa kanya ako nagpapadala yung mga hindi available na oil locally pero hindi practical kasi problem consistency sa pag gamit.
    So kung sa metro manila ka bibili advice ko pinalowest price na rated dexos 1, ILsac gf-5, api sn for gasoline engine.
    Apr 2014
    #3877
    Quote Originally Posted by SkyFlakes88 View Post
    Sir, ano po auto nyo? Pwede mo rin po check sa owner's manual kung ano po ang SAE viscosity at API rating ang recommended. Then later saka natin pag usapan ang brands.
    Mar 2015
    #3878
    Sir Nissan Sylphy po manual. Sa manual po recommended 10w/30 but nun nag Pms po ako 1k nilagay nila elf 5w/40 then sa 5k at 10k pms ako na nagdala oil ko shell 5w/40 till now yun na gamit sir. I'm thinking po next yun castrol na brand po e. Your inputs are highly appreciated sir. Ty
    Jul 2015
    #3879
    Try mo yung edge medyo mahal lang or kahit yung green magnactec 10w40 ok na.
    Pero check api rating baka luma ibigay sayo.
    Like idemtisu api sm pa din. No ilsac rating.
    Mar 2015
    #3880
    Dapat po sir SN rating? Thank you po sa reply sir [emoji4]
    D po ba mas maganda yun 30 kesa 40 sir?
Mineral , semi synthetic or fully synthetic?
