40 is thinner than 50 so if you have observed that lesser oil stay in your engine with a relatively thick oil at 50, then expect it more if you replace your current oil with a thinner 40
Moving from thick to thin oil is always good for the engine and fuel economy but if your engine is leaking oil already then that makes it a bad idea
Sent from my GT-P3110 using Tsikot Forums mobile app
Is it absolutely necessary to engine flush if switching from mineral to FS?
mga sir, mag pa 1st PMS ako ng car, ask ko lng po, which is better casa FS oil or yung available sa market? Mitsubishi car ko.
thanks
mine, since day 1 till i reached 20,000 kms...regular oil with 5,000 kms interval (filter, drain plug and engine oil all replaced).
for gas or diesel? most japanese cars only require api-sn/sm/sl
if you have the evo, they youll want to research on rotella oils..
Guys do u know ba kung anong viscosity ng oil ang nilalagay ng toyota sa vios?
Sent from my SM-G930F using Tapatalk
^ mineral is 20w-50
Synthetic is 5w-40
There are semi-synthetic oils in 5w40 (Shell Helix HX7) and 10w40 (Valvoline, Shell) viscosities. For mineral oil, you can opt for 10w30 (Idemitsu) or 15w40 (Shell HX5).
20w50 is just too thick for small engines. Even with big 4-cylinders (2.0L or more), I would not even recommend it.
sir meron po ako tanong sa mga experts dito..
gusto ko sana gamitin yung MOBIL DELVAC 1 full synth for Isuzu D-max 2017 LS po. pero nakalagay sa manual MOBIL DELVAC MX which is synth blend. ok lng ba full synth gamitin ko? ano kaya safe na ODI?
sa friend ko Monty ride nya gamit din siya MOBIL DELVAC 1 pero ODI nya 15,000 km. tapos sabi ng clasmate ko nagwork sa MOBIL kaya dw 25,000 km to 40,000 km ang ODI ng mobil full synth or 1 year whichever come first.
pero kadalasan nabasa ko pag full synth 10,000 km ODI tapos pag semi-snythetic 5,000 km po.
need lng po advice ano maganda ODI na safe ng engine po.
maraming salamat po
normally we say oci. oil change interval.
intervals depend on filter and oil. if you're using stock filters, follow oci as per reco in the manual aka whichever comes first time or distance.
Hi po. Newbie question here. Ok lang ba gamit kong oil sa altis 2007 ko shell helix hx5 15w40 tapos VIC oil filter or meron po kayong mas magandang ma iirecommend?. 109k napo mileage. Salamat po sa mga magrereply
yellow bottle is very good. api-sl has good additives for older engines.
