Results 1 to 20 of 6586
    Aug 2010
    do turbo diesel need fully synthetic oil, or can i use mineral
    wala kasi ako mabasa sa booklet ng 4m41 na "use fully synthetic oil only" and nag tanong ako sa mitsubishi marcos na ang nirerecomend daw nila eh fully synthetic dahil daw turbo diesel ang makina ko
    Quote Originally Posted by igiwtf View Post
    +1. can i use mineral oil for my 4m40? right now im using semi-synthetic e.
    Basta multigrade na pasado sa API rating na kelangan puwede na. But for new engines, use semi or fully synthetic depending upon your service intervals. You can compute naman whichever will give the best benefit and not much cost.
    for example, twice a year ka lang magpapalit since hindi malalayo biyahe mo, better to use semi or fully syn para ok pa oil mo kahit matagal na sa engine. Kung every 3 months ka magpapalit, multigrade or semi-syn is best.
    Nov 2003
    mineral or synthetic, parehas pwede naman basta you follow the correct drain interval
    Oct 2011
    CF-4 or CH-4 rated by API are designed for turbo charge diesel engine.
    Dec 2009
    buy the best oil with the best specifications( additive package/base oil)...
    pag mineral kaya mostly 5000kms ang recommended change oil because it degrades very easily when used...
    if you use semi synthetic you can extend it a little further provided you use a good filter...(not VIC)
    if you use fully synthetic you can DEFINITELY extend your intervals...and extend it FURTHER with a good filter again...(not VIC)
    the TRUE advantage of fully synthetics over semi and mineral oils is not the interval it can give but the edge in terms of
    *shear protection (oil film strength)
    *soot dispersion (can hold more particles in suspension)
    *fuel economy (high viscosity, superb cold start protection)
    *and resistance to oil oxidation due to the fact that they are synthetics (degradation)
    Nov 2003
    mineral oil is fine if you're very religious with your intervals. if you'd like a bit more leeway with it then better to use full syn oil.
Mineral , semi synthetic or fully synthetic?
