Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Jan 2009
    Last saturday po I had may valve seals replaced. Kase every morning pagstart sobra mausok, na nawawala naman pag mainit na makina. Nang mapalitan yung seals ok naman, nawala na yung mausok na start-up. What is noticeable though is the decrease in engine power. Di naman palyado yung makina pero noticeable mas mahina ang acceleration compared nung bago sya palitan ng valve seals. Tagal mag reach 80 kph even at 5th gear. Could it be improper valve clearance? Di na kase sinukat nung mekaniko yung tappet clearance nung ibalik yung valves, inalog alog nya lang bawat isa at sabi ok na raw yun, basta wala naman daw tukod. If di naman valve clearance, ano po kaya problema?
    Need your opinions tsikoteers!
    thanks po in advance
    ginamitan ng "feeling gauge"?
    dalhin mo sa ibang mekaniko na meron tamang tools sa pagsukat ng valve clearance
    Jan 2009
    hindi gumamit ng gage whatsoever. hinigpitan, tapos inalog-alog then higpit uli, yun na
    Pa-tune up mo sa mahusay na mechanic. Dapat sinukat yung valve clearance at i-check yung timing. Top overahaul ba pinagawa mo?
    Jan 2009
    di naman top overhaul. valve seal replacement lang talaga.
    May pushrod at rocker arm? Clearance should return to previous setting.
    Yun lang ba ginawa sa engine mo?
    Jan 2009
    yup meron pushrod and rocker arm. valve seal lang palit, at dinukot lang daw kase di naman nagalaw ang timing.
    hindi ba talaga ma-avoid messing with the valve clearance when you change the valve seals?
    possible not to mess with them, but its better to check afterwards. it won't hurt double checking clearances
    It can be done. You can check use the short method then insert the filler gauge on the closed valves then adjust those that are off (which is seldom and minimal deviation because of oil) then turn engine 360 degrees then do it again.
mild loss of acceleration :valve clearance kaya?
