Results 1 to 10 of 16
- Jan 2009
- 5
January 8th, 2009 10:02 PM #1Last saturday po I had may valve seals replaced. Kase every morning pagstart sobra mausok, na nawawala naman pag mainit na makina. Nang mapalitan yung seals ok naman, nawala na yung mausok na start-up. What is noticeable though is the decrease in engine power. Di naman palyado yung makina pero noticeable mas mahina ang acceleration compared nung bago sya palitan ng valve seals. Tagal mag reach 80 kph even at 5th gear. Could it be improper valve clearance? Di na kase sinukat nung mekaniko yung tappet clearance nung ibalik yung valves, inalog alog nya lang bawat isa at sabi ok na raw yun, basta wala naman daw tukod. If di naman valve clearance, ano po kaya problema?
Need your opinions tsikoteers!
thanks po in advance
Tsikot Member Rank 4
- 2,716
January 8th, 2009 11:15 PM #2Di na kase sinukat nung mekaniko yung tappet clearance nung ibalik yung valves, inalog alog nya lang bawat isa at sabi ok na raw yun
dalhin mo sa ibang mekaniko na meron tamang tools sa pagsukat ng valve clearance
- Jan 2009
- 5
January 8th, 2009 11:18 PM #3hindi gumamit ng gage whatsoever. hinigpitan, tapos inalog-alog then higpit uli, yun na
- Nov 2008
- 148
January 8th, 2009 11:48 PM #4Pa-tune up mo sa mahusay na mechanic. Dapat sinukat yung valve clearance at i-check yung timing. Top overahaul ba pinagawa mo?
- Jan 2009
- 5
January 9th, 2009 09:30 AM #6
May pushrod at rocker arm? Clearance should return to previous setting.
Yun lang ba ginawa sa engine mo?
- Jan 2009
- 5
January 9th, 2009 11:41 AM #7yup meron pushrod and rocker arm. valve seal lang palit, at dinukot lang daw kase di naman nagalaw ang timing.
January 9th, 2009 03:05 PM #8
hindi ba talaga ma-avoid messing with the valve clearance when you change the valve seals?
- Feb 2008
- 577
January 9th, 2009 04:52 PM #9possible not to mess with them, but its better to check afterwards. it won't hurt double checking clearances
January 10th, 2009 09:32 AM #10
It can be done. You can check use the short method then insert the filler gauge on the closed valves then adjust those that are off (which is seldom and minimal deviation because of oil) then turn engine 360 degrees then do it again.
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
