Results 1 to 10 of 12
April 15th, 2016 11:55 PM #1
Mga sir bakit po Maya mahina humatak yung Hyundai grace ko d4bx makina nag change oil na rin ako at palit fuel filter pro ganun pa din sabi saken ng mikaniko kaya daw mabagal dahil napalitan na ng injection pump pang l300 dapat daw palitan nung pang Hyundai tlga 105 top speed nya mga sir matagal niya pa makuha
April 15th, 2016 11:57 PM #2
April 16th, 2016 12:06 AM #3
Bring it to central diesel along quezon ave...
April 16th, 2016 10:49 PM #5
Which province? Good shops can test if its the injectors, injection pump and timing, fuel pump, low compression etc.
I think major cities have shops for diesels. Dagupan Baguio Ilocos have some. Cebu and Davao/CDO should have some also. Ask your neighbors or the shops in your area.Last edited by StockEngine; April 16th, 2016 at 10:53 PM.
- Oct 2014
- 162
April 16th, 2016 11:15 PM #6
April 17th, 2016 03:42 PM #7
tignan mo sa injection pump body kung magkaiba nga. Lucas (delphi) ang oem pump ng hyundai. Diesel kiki or zexel sa mitsubishi.
mas mataas ang injection pressures ng lucas kaysa diesel kiki/zexel sa aking pagkakaalam.
kung oem ang pump, look for other causes.
air in the lines, bad fuel, water in fuel, binding brakes, worn out clutch, timing, timing belt getting ready to snap (isang senyales din ito yung nanghihina na),etc...
April 18th, 2016 06:00 PM #8
April 18th, 2016 06:03 PM #9
April 18th, 2016 08:55 PM #10
Daming issue ng SU7:grin:
Xiaomi E-Car
