Results 1 to 3 of 3
- Dec 2009
- 1
December 21st, 2009 09:30 PM #1sir, pakitulungan naman po ako sa nissan sentra series 3 ko 1995 M/T.....
since typhoon ondoy, madami na po ako napaayos sa car ko as follows:
1. change computer box (japan surplus ksi wal available local version)
2. change oil
3. drain fuel tank
4. clean servo
5. nasira din po mass air flow sensor kaya nagpalit din ako (japan)
6. ignition coil
7. gas pump (motor only)
8. spark plug
9. clean radiator
pagtapos po maayos e napansin ko mabilis maubos ang gasolina. nagkarga ako 1000 e 89 kms. lng tinakbo wala na. nagkarga uli ako 650 e 64 kms pa lang ubos na rin. pag ini-start ko naman po e nag-istart pero pag apak ko sa gas pedal e namamatay un makina.
ano po kaya possible cause nun? dati po naman di ganun. matipid nga dati e. hope you can help......
maraming salamat po.....
December 21st, 2009 09:52 PM #2
is the MAF sensor from the same engine model or adapted to work with your car?
- Jun 2009
- 325
December 22nd, 2009 01:30 PM #3Did the shop you brought the car has scan tool to check trouble codes? Actually, iba ECU, MAF sensor ng Japan version sa local models. In Japan, most cars are fitted with oxygen sensor while local version don't have.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
