Results 1 to 7 of 7
October 9th, 2011 05:43 PM #1
Do all new crdinengines from toyota, mitsubishi and isuzu have water separators, if yes, where is it and how often do we need to check and replacw iit? Are there any aftermarket filters like baldwin have this?
October 10th, 2011 11:03 PM #2
Kinda hard to give a answer since you gave no specifics on the engine or vehicle make and model.
October 11th, 2011 10:54 PM #3
For a 4m41 3.2liter tdi mitsubishi, a3.0liter d4d engine of a fortuner....
October 12th, 2011 06:57 AM #4
JS Filters :: Product Catalogue is where you can check to get the Baldwin equivalent. The D4D does not have a Fleetguard or Baldwin match.
October 12th, 2011 02:10 PM #5
Normally, there is a float thingie in the filter which will activate the fuel filter light in the event a certain level of water has already accumulated. All one had to do is open the valve thingie at the bottom to drain the water and re-prime the pump.
There are pre-filters like the ones sold by Berrima that have a glass bottom so you can see dirt and water should they be present.
Hope this helps.
October 12th, 2011 07:02 PM #6
Pag may pump primer yung fuel filter head may FS yun. Pero may nakita na rin akong mga engines na fuel filter at hindi fuel separator ang nakalagay sa head na may primer, nagtipid siguro.
October 13th, 2011 02:15 PM #7
it's either a 2-in-1 assembly or separated.
2-in-1 = filter and water sedimentor in 1 canister equipped with a priming pump at the top and drain valve at the bottom.
for "split-type", water separator is the one equipped with the priming pump and drain valve. filter is a screw-on.
hth
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
