Results 121 to 130 of 148
July 24th, 2013 04:02 PM #121
I use diesel fuel as engine flush. Drain your old oil, then put in a similar amount of diesel fuel inside the engine. Run the engine at idle speed only for about 10 to 15 minutes. DO NOT REV IT.
Drain the diesel, (which will look very dirty by now) preferably letting it drip overnight. You can now also remove the old oil filter. Tape a NO ENGINE OIL sign on the steering wheel.
Tip: I recently found out that those big round plastic cake containers from S&R can hold about a gallon of used oil. :D
- Jul 2013
- 22
August 1st, 2013 11:06 AM #123
Roadstar makati or global.. Lowest price guaranteed
October 12th, 2013 09:22 PM #124
- Jul 2011
- 584
June 21st, 2014 03:13 PM #125anyone naka try bumili sa fusion r, may nabasa kasi ako na parang mura doon.
any update sa mga gumagamit ng ceratec?
June 21st, 2014 06:25 PM #126
^I'm using Ceratec on our Vios. So far so good after almost 7000kms. Paabutin ko lang ng 8000 then palit oil na.
Posted via Tsikot Mobile App
- Jul 2014
- 2
July 15th, 2014 12:25 AM #127Sirs I bought Liqui Moly 10w40 512 petot per liter and ceratec 1,547 per bottle.
- Jul 2014
- 2
- Feb 2009
- 63
high idle RPM at engine start
