Mga guru's mahusay ba yung mga carb and fuel system cleaner na hinahalo sa fuels tulad nun Cyclo na brand?Thanx in advance
i tried using STP fuel system cleaner before. i think it was a bad decision and i just wasted my money there. i just stick on using the 3M carb cleaner spray na lang for my lancer EL during tune ups because i see good results using the product.
sir, yang 3M carb cleaner spray na yan eh pwede ba sa EFI? pano ba ang DIY nyan???? gaano ba karami ang e spray dyan? thanks...Originally Posted by zero
having used both, i'd say there's no adverse effect using those two products. i use fuel injector cleaner(the one you mix with the fuel in between fill-ups) and the spray-on carb cleaner. normally, i would use the fuel injector cleaner during my PMS every 5000 kms. as for the carb cleaner, i used it once when my throttle-body becomes dirty (rough idling, erratic idling, etc.).
Originally Posted by ian_rex
yan po ba yong pag biglang taas ang idling? pag start ko kasi nasa 1200rpm then baba na siya for few minutes nasa 600rpm. pero minsan tumataas na naman going to 7500 to 8500 w/ or w/o ac....
zero: Yung 3m na spray sa pinaka mouth lang ng carb ginagamit diba?How do you go about using this bro?? thanx again
oo yun nga. i suggest, try mo muna linisan yung throttle-body mo using spray-on cleaners. hulaan ko, naka-K&N ka? yung biglang taas nang idling sa pag-start,normal yan-kasi pag nasa normal operating temperature ka na, bumababa na yan sa 750 rpm give or take a few.Originally Posted by kools
di ako sure kong naka K&N? ano po ba yong K&N? new lang kasi oto ko galing sa bayaw ko kaya di ko pa gaano alam kong ano mga nakalagay at kong ano ano mga yon... oo pag start ko ng oto nasa 1200 rpm niya then pag medyo matagal na nasa 700-800 rpm na siya. basta ang alam ko yong filter eh di na yong datihan. parang malaking cup lang na nakalagay. remember ko eh parang racing filter ata yon.. yon na po ba yong K&N?
OT: anong gamit ng K&N? thanks
oo racing filter nga yun. either K&N or Simota yan. anyways, palinis mo rin yung throttle body mo, sakit ng mga may racing filter yan talaga.
sir, medyo OT or OT na talaga... ask ko lang, ano ba yong throttle body? buti na nagtatanong kaysa maging tanga ako sa oto koala pa kasi me alam regards sa mga ganyan basta alam ko lang magdrive... pano po pala maglisnis ng throttle body? thanks po uli.
http://www.intenseperformance.com/fu...ttle_body.html
HTH![]()
i use the carb cleaner spray while the engine is off sa automatic choke, vacuum cylinder, carb linkage, manifold heat riser at air intakes, carb butterfly. read the labels na lang po sa kapag tumingin kayo ng 3M sa ace hardware/handyman.Originally Posted by jag_001
mga sir how often should I use my spray-on carb cleaner to clean my carb? naka racing filter din kasi ako, thanks
every tune up lang sa lancer ko.
pero tomorrow, magpa-top dukot overhaul ako. magagamit din itong carb spray
pang-decarbonize sa mga multi-valves and other internal parts of my engine.
