Quote Originally Posted by jag_001
zero: Yung 3m na spray sa pinaka mouth lang ng carb ginagamit diba?How do you go about using this bro?? thanx again
i use the carb cleaner spray while the engine is off sa automatic choke, vacuum cylinder, carb linkage, manifold heat riser at air intakes, carb butterfly. read the labels na lang po sa kapag tumingin kayo ng 3M sa ace hardware/handyman.
