gurus , I noted leaks under my engine sa oil pan ata
feeling ko gasket ang palitan.. tanong ko kung ano pa pwede pang palitan na parts..
kailangan bang i chgnage oil pag na g palit ng gasket??
tnx![]()
tnx![]()
since sa oil pan nakalagay ang oil mo pagalis nito drain din ang oil mo, pwede mo na rin pa change oil sabay mo na, wag ka nang manghinayang kung medyo malinis pa ang oil mo kasi pag nacontaminate ang oil mo baka masira pa ang engine mo mas mahal.
same problem din po ako. Pede ba yan DIY? tanggal turnilyo at palit gasket lang ba yan? ala ba malalaglag na parts jan?![]()
you need to know the proper sequence for the bolts. minsan hindi lumalapat yung gasket if you don't sequence it properly.
I thought I had a leak also on the pan gasket..buti na lang..sa drain plug pala..so new washer lang nilagay.
pa engine wash mo muna and thoroughly dry the engine bago istart. baka sa upper part ng engine yun leak like a half moon gasket sa top? anung engine ba ito?
