Results 1 to 15 of 15
    Dec 2003
    gurus , I noted leaks under my engine sa oil pan ata
    feeling ko gasket ang palitan.. tanong ko kung ano pa pwede pang palitan na parts..
    kailangan bang i chgnage oil pag na g palit ng gasket??
    tnx
    since sa oil pan nakalagay ang oil mo pagalis nito drain din ang oil mo, pwede mo na rin pa change oil sabay mo na, wag ka nang manghinayang kung medyo malinis pa ang oil mo kasi pag nacontaminate ang oil mo baka masira pa ang engine mo mas mahal.
    Dec 2007
    Quote Originally Posted by raine View Post
    word up!
    aite, peace.
    Oct 2005
    same problem din po ako. Pede ba yan DIY? tanggal turnilyo at palit gasket lang ba yan? ala ba malalaglag na parts jan?
    Jan 2008
    Quote Originally Posted by Teddycom23 View Post
    check nyo na rin cam shaft and crank shaft oil seal. napaka hirap mag palit ng oil pan gasket. kung masikip pati exhaust manifold kelangan din kalasin. pag kabit ng oil pan make sure tuyo na ang sealant, let it cure overnight.
    Dec 2003
    salamat hanap n lang ako shop na mura
    Jan 2008
    Quote Originally Posted by enzo18 View Post
    sori, i mean pag kinabit yung oil pan make sure tuyo na yung sealant bago mo i-start ang engine.
    Dec 2007
    nde nde nde!! lagyan mo muna ng Oil yung makina bago mo istart yung makina!! lolz!!!
    aite, peace.
    Jan 2008
    Quote Originally Posted by KBR View Post
    aite, peace.
    oo nga pala
    Nov 2003
    you need to know the proper sequence for the bolts. minsan hindi lumalapat yung gasket if you don't sequence it properly.
    Jan 2008
    Quote Originally Posted by speedyfix View Post
    +1, kahit ilang ulit mo kalasin and ibalik posibleng mag-leak pa rin kung hindi tama pagkakalagay.
    Aug 2007
    I thought I had a leak also on the pan gasket..buti na lang..sa drain plug pala..so new washer lang nilagay.
    pa engine wash mo muna and thoroughly dry the engine bago istart. baka sa upper part ng engine yun leak like a half moon gasket sa top? anung engine ba ito?
    Quote Originally Posted by biboy28 View Post
    tnx
    Don't guess, get a good mechanic to check for the source of the leaks.
    Oil can leak from a number of places on an engine. Guesswork wouldn't help solving it.
    Oct 2005
    Sir ano po ba proper sequence ng bolts? Simula ba sa gitna palabas or sa dulo papunta sa gitna na sabay ang magkabilaan na turnilyo? Thanks po.
leaks
