Results 1 to 10 of 21
- Aug 2011
- 5
September 25th, 2012 02:14 AM #1Guys any idea on which shop does a leakdown testing service...or a shop that does a compression test?...Any idea on how much...Thanks =)
- Jun 2005
- 3,774
September 25th, 2012 08:26 AM #2compression test, speedyfix, servitek or any decent shop. costs 200-500
leakdown test: machine shop. costs 3k-6k plus mechanic labor plus parts. usually sa overhaul ito
September 25th, 2012 10:30 AM #3
Leakdown test: 1,600 php. Speedlab.
3-6k is too much. That's the cost for a top overhaul already.
- Aug 2011
- 5
September 27th, 2012 01:54 AM #4Thanks for the input guys...do all servitek centers have compression test or just selected few? I have been asking some shops about this but to no avail...I haven't tried asking servitek though...
September 27th, 2012 09:07 AM #5
Not many people do compression tests, though the equipment is pretty simple. Speedlab does compression, too.
- Jun 2009
- 325
September 29th, 2012 10:34 PM #6Gasoline and diesel engines have different types of compression gauge. For gasoline engines, the pressure range is from 0- 250 psi and for diesel engines the range is from 0- 800 psi. In testing gasoline engines, you need to remove all the spark plugs and disable the ignition system and insert the test hose to the spark plug hole of each cylinder. For diesel engines,its a different story. You must have a glow plug adaptor or nozzle adaptor to fit on each cylinder for compression testing. Most of independent service shops don't have this instrument unlike the casas.
- Jul 2010
- 570
- Feb 2007
- 148
October 2nd, 2012 09:47 PM #8Para saan po ang leakdown test? Is it included in casa PMS or additional service?
October 2nd, 2012 10:33 PM #9
Compression testing gives you a cylinder to cylinder comparison of absolute pressure numbers.
Leakdown testing tells you where the pressure is leaking out to... Out the valves, through the piston rings or out the headgasket.
Granted, diesel is different... but it's the gas tester I'm talking about. Very few shops have a universal tester for gas engines, despite it being a very simple machine.
- Jun 2005
- 3,774
October 2nd, 2012 11:36 PM #10
