Guys any idea on which shop does a leakdown testing service...or a shop that does a compression test?...Any idea on how much...Thanks =)
compression test, speedyfix, servitek or any decent shop. costs 200-500
leakdown test: machine shop. costs 3k-6k plus mechanic labor plus parts. usually sa overhaul ito
Leakdown test: 1,600 php. Speedlab.
3-6k is too much. That's the cost for a top overhaul already.
Thanks for the input guys...do all servitek centers have compression test or just selected few? I have been asking some shops about this but to no avail...I haven't tried asking servitek though...
Not many people do compression tests, though the equipment is pretty simple. Speedlab does compression, too.
Gasoline and diesel engines have different types of compression gauge. For gasoline engines, the pressure range is from 0- 250 psi and for diesel engines the range is from 0- 800 psi. In testing gasoline engines, you need to remove all the spark plugs and disable the ignition system and insert the test hose to the spark plug hole of each cylinder. For diesel engines,its a different story. You must have a glow plug adaptor or nozzle adaptor to fit on each cylinder for compression testing. Most of independent service shops don't have this instrument unlike the casas.
Para saan po ang leakdown test? Is it included in casa PMS or additional service?
Compression testing gives you a cylinder to cylinder comparison of absolute pressure numbers.
Leakdown testing tells you where the pressure is leaking out to... Out the valves, through the piston rings or out the headgasket.
Granted, diesel is different... but it's the gas tester I'm talking about. Very few shops have a universal tester for gas engines, despite it being a very simple machine.
Ah. I've done that too. Painful. Cracked the cylinder head on my Sentra in a flood. We had an odd burp in the coolant temps after the overhaul that we couldn't trace... and that was the finding.
Thanks for the input. So basically, konti lang ang difference ng gastos pag general overhaul and pag bumili ng surplus? Parang mas may advantage ang pag bili na lang ng surplus cause I do have plans of getting a stronger engine para mas gumanda ng konti ang takbo since I own a matic car.
I don't know kung what type ng compression check ang ginawa eh. Di din nilagyan ng oil yung cylinders. Yun lang yung reading na binigay sakin. Loss compression lang engine ko e, di naman nagbabawas ng langis masyado. Do you have figures sir ng rough estimate ng general overhaul?
Should get a leakdown to determine why the compression in those two cylinders is low. It can basically pinpoint where the pressure is going, whether out the piston rings or through the head gasket.
Dati low compression 4G13 engine ko at pinalitan ko ng 4G15 engine. Almost same lang result ng FC 6km/ltr. Hindi ko kasi pina overhaul yun nabili ko surplus na engine 4G15.
So, I end up na ako na mismo nag DIY rebulid ng 4G13 engine ko para sure ang pagkagawa at mas tipid pa. 12K gastos ko kasama na yun machine shop rebore at relining and parts at mounting ng 4G13 uli sa kotse ko. Almost 160 PSI result dry compression test ko sa mga cylinders ko. Hindi na masama sa first time engine rebuild ko.
Nakatabi na lang 4G15 engine ko ngayun at general cleaning ko uli lahat ng parts para benta ng chop chop.
If I were you. General overhaul mo na lang dating engine mo. Kasi yun surplus engine ay pa-overhaul mo para tipid ka sa gas and for better performance. Pwera pa dito yun sakit ng ulo at gastos ng pag change engine LTO.
