Results 1 to 10 of 20
- Sep 2014
- 7
September 23rd, 2014 05:28 PM #1Good day ka-tskikots!
I have a Lancer Boxtype model which was a pamana from my grandad and also my first car. It seems may problem sa carburetor which is leaking fuel around the base sa may hole kung saan nakalagay yung throttle ata yun. May repair options pa ba yun or I'll need to buy a replacement carb? If so, where and around how much? Thanks!
September 23rd, 2014 05:30 PM #2
Malamang seal lang na sira.
Rebuilt kit pwede diyan sir, hindi lang ako familiar kung saan meron.
- Feb 2014
- 48
September 23rd, 2014 05:35 PM #3Congrats sa 1st Car mo TS
Regarding sa Price ng pa repair ng Carb nun August ata nag pa repair rin ako ng Carb sa may Novaliches Php750 ang siningil sakin.
- Sep 2014
- 7
September 23rd, 2014 05:36 PM #4
September 23rd, 2014 05:58 PM #5
Ahh gasket lang pala. Kasama ata sa repair kit yun.
May mga rubber seals yung carb or o ring kung tawagin. Kala dun tumatagas.
- Sep 2014
- 7
September 23rd, 2014 06:11 PM #6Di ko maexplain ng maayos haha. Di sa may gasket yung leak e. Hmm yung leak kasi sa may part ng throttle plate na nakakabit sa mismong base, example etong hole > O tapos nakasuksok dyan di na sakto sa hole na yan kaya may space para tumagas yung gasoline. Eto sana maintindihan ang drawing kong malupet haha.
September 23rd, 2014 06:37 PM #7
Bro Parang o ring lang. Hindi ko din sure.
Pacheck na lang pero mura lang rebuild ng carb.
- Sep 2014
- 7
September 23rd, 2014 06:52 PM #8
- Nov 2008
- 641
September 24th, 2014 10:29 AM #10Eto yung cast iron part ng carburetor, right below ng aluminum floater tank at injector. Had that same experience before sa boxtype ko, nung sinubukan kong baklasin wala akong nakitang seals, I guess lumuwag na yung shaft casing (yung naghohold ng throttle valve) due to wear. Nagtanong tanong ako sa shops and they recommended na either bago o surplus. Swerte nakakuha ako ng surplus (yun throttle body lang na cast iron) sa may evangelista, mga 450 pa bili ko nuon. Pero that was way back 2006 pa
Kapag tinuloy pa yan sigurado magtatagal dahil makikialam ang Taguig LGU.
Makati Subway. Completion date: 2025
