Results 21 to 30 of 57
- Dec 2002
- 2,335
February 23rd, 2007 10:08 AM #21work horse ang diesel motor. It's a no nonsense engine that will keep running even beyond 300,000km. Tama si otep yung mga tao na nagsasabi nyan hindi pa nakakakita ng engine under the hood
February 23rd, 2007 11:03 AM #22
onga pala.. followup ko din po tanong ni sir afrasay... how about direct injected diesels? i heard lots of horror stories about it po.. about our local diesel not being clean enough?
totoo po bang nagbabara lang is yung japanese brands dahil they use denso injectors which are sensitive sa dumi ng diesel?
korean and euro cars naman dont suffer from this dahil they use bosche?
tnx
February 24th, 2007 12:45 PM #23
Most direct injection systems are not that sensitive. Ang disadvantage ng DI is mas maingay siya (due to the inherent design of igniting fuel without a pre-chamber) kaya karamihan ng DI engines may plastic shroud to lessen noise levels.
Ang mas sensitive ay CRDi which uses very high pressure fuel. But Hyundai and Kia CRDi systems have been pretty much reliable as they have been in the market for quite a while (nauna pa sila sa mga Japanese na maglabas ng CRDi system locally).
Toyota lang naman ata ang nagkaproblema sa CRDi systems nila. Hopefully by this time nagtake na sila ng steps to solve the problem.
Yung Trooper 3.0 ba ay CRDi?
- Aug 2003
- 9,720
February 24th, 2007 12:54 PM #24just speculation, pero
-- karamihan ng diesels are RWD right? mas expensive ata magmaintain ng RWD kesa FWD?
-- usually kasi diesel vehicles are larger than petrol-fed cars. larger vehicles = larger parts = more expensive to replace. diesels also need more oil di ba? mantakin mong 2 gallons ang nagagamit sa PUJ, compared to 3-4 liters lang sa passenger car? di kasi nag uso ung light duty diesels dito sa atin e
-- and as mentioned, usually workhorse/panlaspag kasi talaga ung diesels; they're subjected to more abuse than private cars.
February 24th, 2007 02:20 PM #25
sir badkuk..
soon siguro magkakaroon din tayo ng light vehicles na.. diesel.. like they have in europe.. actually.. nagsisimula na yata eh.. sa alam ko meron na yung hyundai getz.. but.. medyo mahal.. compared sa gasoline version nya...
sir otep...
does that mean.. ok ang new pajero engine 4m41 for philippines? so.. ang nagkaproblema lang po talaga is yung toyotas and.. troopers? how about crosswinds and alterras? alam nyo po?
eh yung mga euro cars kaya na diesel? say... 530d... and.. yung much awaited 300C diesel na hindi parin nilalabas sa pinas... it is said that yung engine ng 300C ay mangagaling sa benz.. na 3.0L CRD... na... makakatakbo ng 0 to 100 in 7.2 sec.. imagine.. isang napakalaking sedan na diesel.. that can match an SIR's 0-100? which is said na dapat same price pag nilabas sa.. 3.5L v6.
February 24th, 2007 02:42 PM #26
- Feb 2007
- 12
February 24th, 2007 03:23 PM #27[SIZE=3]I'm an owner of an Isuzu elf 4be1 light truck..in my experience with diesel engines its more cost effective in maintaining one. as long as you regularly check for wears on your fan belt, loose bolts in you engine bay and engine support, wears on the wires of your alternator, your atf level, steering performance, battery water level(which is commonly neglected in diesel engines) including its clamps, check of oil level(which i do every day),regular change of engine oil and its oil filters(every 4T kms or roughly 2mos of daily use),water level in your radiator and its reservoir,cracks in your radiator hoses and a clean air filter..then your ride will give you a smooth start every morning you crank your engine..as long as you all of those mentioned above wala kang aalalahanin..ive been using mine for the past 6 yrs na and every visit to the emission test center less than 1% pa din ang grade nung makina ng truck...much to the delight of the emission personnels..ang pinaka major na naging problema ko is palit lang ng clutch disc..hehe..as with your injection pump being cleaned..hindi basta basta ginagalaw ito..unahin mong ayusin/palitan air filter mo baka marumi na at clogged o kaya yung hose na humahawak sa housing ng air filter(baka luma na at malambot kaya napitpit at walang mahigop na hangin) kaya mausok na sya..thats from my experience...my 2 sentimos[/SIZE]
February 24th, 2007 03:33 PM #28
- Feb 2007
- 12
February 24th, 2007 03:49 PM #29pahabol pa..aside from sir oteps response(which I 100% agree) kung mausok na diesel engine mo..wag yung injection pump ang sisihin agad ito muna unahin nyo:
1) check kung marumi air filter at yung hose na humahawak sa air filter housing(baka luma na at malambot na ito, kaya nag co collapse yung hose nyo hence humhina hatak ng makina at mausok..(basic)
2) ipalinis nyo lang muna yung burn/heat plugs nyo (conterpart ng spark plugs sa gas fed engine)..in time nagkakaroon din ito ng mga waste/deposits at corrosions.(mekaniko kailangan nyo dito)
3) ipa check nyo engine compression..minsan di nyo namamalayan na overheat na pala kayo kaso takbo pa rin at ang tinatamaan dito ay yung cyclinder head. maswerte na kayo kung repaste lang ng cylinder head ang ipapagawa kaysa sa replacement ng buo at siguradong butas ang bulsa nyo dito (ito naman ay kung paulit ulit kayong na o overheat)
4) kung sadyang mausaok na nga..ipa check nyo na sa calibration center at baka pinasukan ng tubig yung fuel tank nyo o kaya ay may halong tubig yung diesel na pinakarga nyo at corroded na yung mga needles sa loob ng injection pump..minsan kasi yung akala mong murang diesel e may halo palang tubig kaya mapapamura ka sa gagawin nito sa sasakayan mo :p
...at kung pagpipilian nyo ako kung alin sa diesel o gas na makina, sa diesel na ako..hehe..di ka basta ititirik nito sa baha(wag lang pasukin ng tubig yung air filter mo..at pag nangyari ito..paktay..katok ang makina mo 100%) o sa akyatan kahit na ba kargado ka..pagtyagaan mo nga lang ng konti yung noise level at sadyang mas maingay ang dieselLast edited by mangkaryas; February 24th, 2007 at 04:03 PM. Reason: additional info
- Aug 2003
- 9,720
February 24th, 2007 05:04 PM #30
