It's called detonation or tope...
Timing isn't correct. Have it checked or manually retard it. If you have a car with a knock sensor, then have that checked since the knock sensor prevents detonation from continuing.
Using higher octane gas is a temp fix, unless your car requires high octane to begin with.
