Results 1 to 14 of 14
    Jan 2011
    i recently bought a second hand dmax 2005 AT for farm use. im really disappointed with the poor FC of this dmax i bought, which is is around 7km/l only. wala akong problema sa hatak, lakas ng torque, 15 sacks ng feeds, kayang kaya. yng FC lng talaga ang concern ko. any suggestions na mag improve ang FC or sadyang ganito na talaga ito dahil may kalumaan na?
    Oct 2015
    Try changing all fluids and filters and see if that helps. 7Km/L doesn't sound that bad, apart from condition FE/FC depends most on the load you put on the car. Fully loaded like yours used mostly on low gear (i presume) in the farm, 7Km/L is actually good fuel mileage.
    Quote Originally Posted by shelu View Post
    7 kpl... in an AT... with heavy roads... in the farm?
    that's not bad, i think.
    have it tuned up and see if it improves.
    Jan 2011
    thanks for the replies sirs. at least, my worries are gone. i thought something is wrong with the pick up. i read somewhere that dmax is around 20km/l fuel efficiency. at dahil may kalumaan na ito, expect ko na nasa 10+k/l pa rin siya. di kasi marunong ng manuall si mrs, kaya matik binili ko. subukan ko rin palitan lahat ng filters, baka sakaling mag improve pa.
    Apr 2012
    20km/l is a joke. Kahit pa highway driving yan. Knowing na 3.0 or 2.5 ang engine ng Dmax kaya expect it to be lower than 10km/l lalo pag heavy loads
    Sent from my LG-H818 using Tapatalk
    Mar 2016
    Having run a new (in 2010) 3.0L D-Max in Malaysia, I never really saw much over 12km/L in mixed driving. Maybe 15 on a long run if I was gentle. Off-road on the jungle tracks it was below 10, so you're not doing too bad.
    Clean fuel and air filters, as said, are the trick.
    Mar 2016
    Having run a new (in 2010) 3.0L D-Max in Malaysia, I never really saw much over 12km/L in mixed driving, and that's with no load. Maybe 15 on a long run if I was gentle. Off-road on the jungle tracks it was below 10, so you're not doing too bad.
    Clean fuel, oil and air filters, as said, are the trick.
    not true. my officemate owns a dmax, manual. best he can get is 15 kpl.
    7km/l is Normal. Mine also go down to 5 km/l in city traffix. My other pajero nasa 5km/l. Mainit at saka traffic. Can't help it.
    Jan 2011
    Quote Originally Posted by kevinworld View Post
    salamat sir, akala ko talaga sira ito.
    Feb 2016
    Mas malakas din kumain ang matic compare sa manual sir.
    Sent from my B1-A71 using Tapatalk
    Aug 2004
    20 km/l is indeed possible, but you have to be on a straight and level highway at around 70 km/h. Can't do it at 90-100.
    In heavy use, depending on the load and speed, 7 km/l is not bad.
    Feb 2009
    If I read it correctly, you wanted your vehicle to have a bigger appetite for petroleum?
    Jan 2011
    hindi po sir, nagtanong lang po ako pano tumipid ang kunsumo ng krudo. akala ko kasi, nasa mahigit 10km/l ang FC, yon pala, nasa 7km/l lang. halos magkapareho lang ng kunsumo ng CANTER truck pala.
poor fuel consumption -dmax
