Mga sir, minsan po kasi pagstart ko ng ride ko one click lang , minsan naman wala talaga klik lng sya parang patay yung battery.try ko minsan pihit ko susian talagang ayaw .tsek ko yung battery terminals ayos naman mahigpit lahat ng posts.minsan wala po talaga redondo ,pero pag minsan pag klik nya redondo then start agad.
battery ko po pala is motolit na MF yung puti kaso mga more than 1year na rin to etsaka medyo me umbok na sa gilid. alternator po is surplus and two times na sya napalitan .
sa tingin nyo sir , palitin na ba talaga battery ko ?or me ibang sira pa to?any idea po bakit parang di consistent yun starting ko?
How long is your battery? If it is just a new one then the other thing I could suggest is the starter motor. Maybe a worn carbon, or solenoid, just have a reputable electrician check your car. Good luck.
bro, frst thing first. your battery is more than a year old for a white moto, baka mahina na as you mentioned meron bukol. pag ok battery, then you can go to the rest of what has been mentioned above.
yun po pala starter napalita n rin dati yun ng reconditioned na starter since tumirik na rin ko dati.
so bale yung alternator ko napalitan na sya ng 2 times first is recondiioned nung nasira e hanap na lang ako surplus.
medyo madalang din kasi gamitin yun ride ko e , ,oo nga pala its a galant 7G sya.
isip ko na rin siguro na battery muna paliatan medyo nagiipon lang muna!hehehehe
tsek ko na rin po grounding nya!,nag DIY rin kasi ako ng ground kit nun e kaso na 2 point pa lang ,dagdag ko pa yun ng 3 point dapat e,kinulang sa oras e hehehe
