Results 1 to 7 of 7
    Feb 2006
    mga Sir,
    Patulong naman po ,
    Mga sir, minsan po kasi pagstart ko ng ride ko one click lang , minsan naman wala talaga klik lng sya parang patay yung battery.try ko minsan pihit ko susian talagang ayaw .tsek ko yung battery terminals ayos naman mahigpit lahat ng posts.minsan wala po talaga redondo ,pero pag minsan pag klik nya redondo then start agad.
    battery ko po pala is motolit na MF yung puti kaso mga more than 1year na rin to etsaka medyo me umbok na sa gilid. alternator po is surplus and two times na sya napalitan .
    sa tingin nyo sir , palitin na ba talaga battery ko ?or me ibang sira pa to?any idea po bakit parang di consistent yun starting ko?
    Nov 2007
    How long is your battery? If it is just a new one then the other thing I could suggest is the starter motor. Maybe a worn carbon, or solenoid, just have a reputable electrician check your car. Good luck.
    Threx666,
    Pa-check mo starter motor, baka worn na yung carbon brushes, then palinis mo na rin yung armature. Check mo rin condition nung solenoid.
  4. #4
    baka bendix drive ng starter mo din needs replacement.
    Right. How old is the battery and how old is the car?
    If the battery is ok then the starter motor should be checked....carbon brush or bearing,
    If the car is old check mo ang grounding wire from the battery terminal to the car body and engine body...baka loose or cut off.
    Jan 2003
    bro, frst thing first. your battery is more than a year old for a white moto, baka mahina na as you mentioned meron bukol. pag ok battery, then you can go to the rest of what has been mentioned above.
    Feb 2006
    maraming salamt po sa lang mga sagot mga sir,
    yun po pala starter napalita n rin dati yun ng reconditioned na starter since tumirik na rin ko dati.
    so bale yung alternator ko napalitan na sya ng 2 times first is recondiioned nung nasira e hanap na lang ako surplus.
    medyo madalang din kasi gamitin yun ride ko e , ,oo nga pala its a galant 7G sya.
    isip ko na rin siguro na battery muna paliatan medyo nagiipon lang muna!hehehehe
    tsek ko na rin po grounding nya!,nag DIY rin kasi ako ng ground kit nun e kaso na 2 point pa lang ,dagdag ko pa yun ng 3 point dapat e,kinulang sa oras e hehehe
Intermittent Start minsan one clik minsan ayaw
