[SIZE="6"]New Engine Combusts Old Ideas[/SIZE]
[SIZE="1"]By Dan Orzech| Also by this reporter
02:00 AM Aug, 28, 2006[/SIZE]
If your next car gets twice the gas mileage of your current vehicle, and belches out only a fraction of the pollution, you may have Carmelo Scuderi to thank.
Scuderi, a Massachusetts engineer and inventor, started tinkering with the fundamentals of the internal combustion engine when he retired in the mid-1990s. The result was a radical new design that could make engines for anything from gas-powered lawn mowers to diesel locomotives lighter, far more efficient, and a whole lot easier on the environment.
Scuderi died in 2002, shortly after patenting the basic concept for his engine. Since then, his children have made it their mission to bring the engine to market. Five of them now work full time for the family startup, the Scuderi Group.
Scuderi began by splitting the heart of the internal combustion engine -- the chamber where air is compressed, mixed with fuel and then ignited -- into two separate cylinders, linked by a passage. Air is compressed in the first cylinder, and then shot through the passage into the second cylinder, where it mixes with the gas and burns.
The general idea of a split-cycle engine has been around for a century, but none have ever matched the efficiency of traditional engines. Scuderi believed he could solve the problem by pumping highly pressurized air from the compression cylinder into the combustion chamber, and then allowing the fuel and air to ignite when the head of the piston was already moving away from the top of the combustion cylinder.
The method was counterintuitive, because it creates a condition known as firing after top dead center, considered a cardinal sin in engine design since at least the days of Henry Ford.
"In a normal engine, firing after top dead center doesn't work, because the piston will outrun the flame, so you can't build up any pressure," says Scuderi's son, Sal. In the Scuderi engine, however, the combination of highly pressurized air and firing after top dead center creates a highly turbulent environment where the fuel and air ignite explosively, producing far more power than conventional engines.
So far, the engine exists only as a computer model. Two real-life prototypes -- one diesel and one gasoline -- are under construction at the Southwest Research Institute, an engineering research lab in Texas, and are due out next year.
While it is possible that engineering problems may yet emerge, those involved in the project believe the prototypes will work as planned.
Computer-generated models are universally used in the automotive industry to design new engines and other parts, and are considered extremely accurate in predicting performance.
Those models show the combustion in a Scuderi engine will be not only more powerful than conventional engines; it will also, surprisingly, be cooler. That means it will spew out far fewer pollutants than today's engines do.
The Scuderi engine could even boost mileage by recapturing energy normally lost during braking, as do hybrid cars. "Unlike current electric hybrids which store the energy in a battery, we are able to store energy in the form of compressed air," says Sal Scuderi. That can be done by simply adding a small air-storage tank, which costs far less than the generators and banks of batteries gas-electric hybrids need.
While working models of the Scuderi engine won't see the light of day until next year, the radical design is already attracting a lot of attention in the automotive world. The company is in talks with big automakers, and when it showed off the new engine at a major automotive-engineering conference in Detroit earlier this year, the Scuderi booth was mobbed.
exciting news ah... i wonder which automotive company will be the first to apply this new technology? and since the article mentioned compressed air storage tanks... could this compressed air be possibly used to speed up the turbine at lower rpms, and effectively eliminate turbo lag in turbocharged cars?
