Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Nov 2006
    just had a change oil & tune up & spark plug n air filter change...napansin ko parang mas lalo lumakas sa gas...ano kaya problem ng car ko? accord exi a/t owner here...thanks for replies
    Nov 2003
    what oil and oil viscosity did you use? what plugs? baka mali yung nakabit mo.
    Nov 2006
    mobil special oil & ngk platinum..sobra hassle lakas masyado sa gas
    Quote Originally Posted by macho palito View Post
    how much is your gas spending before?
    how much do you spend now?
    Nov 2006
    b4 tuneup 1,200/wk now 2k/wk
    Aug 2004
    The question isn't what the name of the oil is, but the weight.
    For example, if you go from 10w40 to 20w50, you will notice a difference.
    And, as for the spark plugs, what specific model of NGK? If the spark plugs are too high or too short, this may affect engine power and consumption.
    Nov 2006
    10w50
    as for spark plugs...not sure on the specifics basta ngk platinum
    Aside from the change of oil and A/F. Did they adjust anything else e.g. idling, timing advance/delay, air/fuel mixture, valve clearance?
    Bumilis at responsive ba yung performance ng car after?
    Nov 2006
    adjusted valve tappets...also had the distributor oil seal & gasket replaced...tumatagas kasi langis dun sa part na yun...ska nung ni road test ko bumabagsak idling kaya pinataas ko konte
    Jun 2006
    possible kaya na mali ang adjustment ng valve?
    Nag TDC#1 ba sila ng before puling out your distributor?
    My suspect is they did not get the timing correct when they returned the distributor. This is the reason also na bumaba ang idling after the job, increasing it will not correct the timing. Wild guess lang po sir.
    puwede din na nasobrahan ang adjust sa idling
    May 2007
    hi guys,
    have the same problem. i own a 97 honda accord VTI-S, automatic. i used to experience between 6 to 7 km to a liter, and slightly below 6 whenever i drive aggressively. about 2 1/2 years ago, i installed the khaos gas saving device. i noticed that my consumption just averaged around 6 km to a liter. i used it for a year and then removed it. last year, after i had it tuned up sa casa, i noticed that my consumption even went below 6. it was now averaging about 5.5 km to a liter, hindi pa mabigat yung paa ko nyan. i normally have my car checked and tuned-up sa casa. two months ago, after my last tune up, i noticed that my consumption is now below 5 km to a liter.
    casa changes spark plugs every 10,000 km and changes oil every 5,000 km. i use their spark plugs and oil. the oil they put in my car is Honda genuine oil 10 w 30.
    ano kaya ang cause ng increased consumption? is it the oil? kung hindi naman oil, may problema na kaya yung makina ng kotse ko? timing lang kaya ang problema? any ideas where i can have these items checked aside from casa?
    Jun 2006
    franz29,
    Try speedyfix. Expert sila with Hondas. His address and contact number is on his sig.
    May 2005
    10w50
    10w50 shoot! kaya lumakas
    tinaas mo rin pala idling, lalakas nga consumption mo. may reason kung bakit bumabagsak idling. pa repair mo na lang raising the idling higher than normal will not solve the problem
    Sep 2005
    here's the culprit. saka baka mali yung pagbalik ng distributor o-ring mo. hth
    Nov 2006
    may chance ba na mali pagbalik distributor ko kaya malakas sa gas? e dba pag mali yun, papalya car ko? binalik ko na nga sa shop na pinagpagawaan ko para icheck baket lamon sa gas, they tried fixing the timing pero parang ganun pa dn consumption ng gas.
    baka meron kayo ma suggest na magaling na shop sa alabang/las pinas area kung san ako pde pa tono..tnx
    Feb 2007
    it will be worth it driving all the way to speedyfix in shaw, di ba sir migs?
    Nov 2006
    anong magandang time pumunta sa speedyfix para ipacheck? yung konte lang tao sana para maisalang na agad
    Jun 2006
    sir Migs post naman kayo ng site map ng shop sa shaw then ask ko lang yung charge pagnagpacheck-up ng kotse. Balak ko din pacheck sana.
increased fuel consumption
