Results 1 to 4 of 4
October 27th, 2003 11:23 AM #1
Ano po kailangan icheck if i'm burning oil?
Nag whiwhite smoke po oto ko eh... What parts and stuff ang dapat pacheck? Tenks po.
October 27th, 2003 11:29 AM #2
kung white yung smoke, i guess your engine is burning coolant and not oil.
napapansin mo ba kung nauubos ang engine oil mo? If yes, baka blown na yung engine. You will need an overhaul if this is the case.
October 27th, 2003 12:38 PM #3
i can be valve seals, top over haul lang. but i can also be the rings so complete overhaul na. check mo ang dip stick when the engine is on, if there is smoke na malakas it cold be the rings, blow by na. or check the breather if oil comes out together with white smoke.
October 27th, 2003 08:03 PM #4
Yung W123 ko kahit after overhaul medyo whitish smoke. Best to check if you are indeed consuming oil or coolant by checking the volumes of the respective fluids themselves.
Hindi pa kasi hi-tech ang engines ng W123 kaya medyo may usok. Pero hindi naman black.
the hybrid corolla cross looks more appealing at those prices.
Mitsubishi Xforce
