Results 1 to 10 of 39
- Dec 2006
- 234
October 16th, 2010 06:08 PM #1Caltex with Techron vs. bottled fuel injector cleaner, like STP - do they have the same effect?
October 19th, 2010 06:48 PM #3
I'd stay away from bottled injector cleaners if i were you. Most modern EFI engines do not need these cleaners. Please refer to the Car Bibles website and do a search on fifth gear, it does not do anything to your engine, and may reduce km/l fuel consumption at the least.
- Dec 2008
- 421
October 21st, 2010 01:23 AM #4I popped in a fuel injector cleaner 2 weeks ago when my engine was making this strange sound, we initially thought it was dirty injectors for my FD but it was due to the engine mounts pala. Anyway, i've noticed smoother engine running, increased low end torque and better FC. I guess a bottle wouldn't hurt every 10K km. I use ordinary unleaded fuel
- Jun 2011
- 1
June 12th, 2011 05:42 PM #5Can you please specify the exact name of the fuel injector cleaner 2 that you use?What brand.?thank you.
June 13th, 2011 12:28 PM #6
No need. Just do a tankful of Blaze or V-Power every few tanks if you want the same effect.
Using Blaze is like doing a double-espresso shot of fuel cleaner... it's so potent that it causes hard-starting for some, so you may want to dilute it 50:50 with regular gasoline.
But if your motor likes Blaze, like mine does... it's great.
- Jun 2017
- 15
January 17th, 2018 09:59 AM #8
- 54,304
January 17th, 2018 10:07 AM #9
January 17th, 2018 12:27 PM #10
Bakit nga ganon doc? I have the same feeling every oil change which is either true or psychological. But then, there are times in between oil changes that I feel the car is more responsive, and sometimes it feels like it's dragging something.
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
