Originally Posted by
mangdencio
it's on side of the carb morpheus, you know where the throttle linkage is, yung end ng cable connecting d gas pedal to the carb...it's usually a slotted (flat head) screw protruding...it's turned counterclock wise till the throttle linkage stops, then 6 - 8 full turns clockwise to the desired idle speed...use a a designated dwell/tachometer and not the dashboard tachometer for a more accurate reading/ adjustment.
