Results 1 to 10 of 13
February 1st, 2009 03:50 AM #1
Under warranty pa po pala, so eto po sabihin mo:
As I start the engine, the idle rpm abnormally drops down near zero then after approximately 3 secs it goes up to its normal idle rpm of 650 and I already encountered this twice
Tsikot Member Rank 5
- Nov 2003
- 3,848
February 15th, 2009 11:30 AM #2could be the servo or a dirty throttle. shouldn't be that hard to fix on a relatively new car.
- Sep 2007
- 215
February 16th, 2009 11:54 AM #3pa check mo yug air cleaner mo ... or baka may hose lang natangal sa may throttle
THE AUTO SPECIALIST
- Mar 2006
- 607
February 17th, 2009 05:45 AM #5it has to be checked by the tech , pero you can ask the dealership to get it scanned for any codes or to perform some basic tests.
i.e.smoke test for any vacuum leaks or a throttle body cleaning maybe.
February 20th, 2009 11:17 AM #6
hi Yen,
just saw this thread. i had the same problem with my Sentra as yours after i had my headlights changed to XP sa Petron. I don't know if meron sila nagalaw or something, but the idle RPM dropped from 850 to 400 with A/C, 300 if walang load.
brought it to NGO- Libis, kinabitan lang ng Consult II, then dun in-adjust yung idle RPM back to 850. ayos na ulet.. la pang 10mins.
SA Remo ang nag-assist sa ken. Hope yours get fixed as well.
Cheers!
February 20th, 2009 12:42 PM #7
190,429 cars were sold in PH, as of May 2025 | TopGear PH...
Car Sales Data (2025)
