In my case sa Galant M/T ko, nginig din, yun pala nabali na yung turnilyo na humahawak sa engine support ko, parang humina ang hatak and pangit idling. Nung naayos oks na.
actually napalitan na ng brand new servo motor .
- i believe nuong kinabit nila ito... tinangal nila iyon connection pole ng battery. But not sure how many minute bago i connect.
- do you think kung sakali hindi nasunod ito .... use less ang pagawa ng reset.
Ask ko lang are this the same application if ECU or ECI ang
now I'm planning to let them check the engine support and palinis iyong throttle.
remarks:
when I start up the engine
a. After startup RPM=Approx 1200
b. Sa "N" or "P" position at normal engine temp. RPM= Approx. 950
c. Sa "D" or "R" position RPM= Aprrox 650-550
If A/C ON
d. Sa "N" or "P" position Aircond "On" RPM =Approx 1000
e-Sa "R" or "D" 750 - 600 >>>lalo na pag napreno ka... nanginginig siya...
let me know if you still have idea to solve this..... for the time being I'll let them check the engine support... and trothle ..
