Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    May problem lang po ako sa car ko. The symptoms are as follows:
    1. Low RPM with headlights and aircon on and during full-steering... halos mamamatay makina...
    2. Brakes are weak with A/C on... ok naman with A/C off..
    3. Halos mamamatay din ang makina when backing-up... lalo na kapag naka on ang headlights..
    Idle RPM is normal naman.. around 750... bagong palit din ang sparkplugs.
    Ano po kaya problem nito?
    Thanks a lot ...
    Apr 2009
    I'm no expert sir but I think it's either weak alternator or most likely, compressor belt locked too tight or compressor clutch bearing close to stucking up or giving up.
    Is your car using carburator or EFI?
    If it's using carb, another possibility could be that the idle-up mechanism for aircon is either clogged or no longer working.
    Check the battery terminals.
    Sounds like you have a bad connection to the battery.
    Clean the terminals and re-tighten.
    Quote Originally Posted by isa1023 View Post
    My Car is EFI --- Sentra ECCS
    Additional symptom, RPM drops and headlight dims when aircon is on turned on...
    Most likely a malfunctioning alternator or battery. Have it checked by an electrical specialist. A battery store can check your alternator charging/battery status for free.
    Jun 2010
    sir bili kayo ng voltmeter (digital preferably around 900 pesos lang naman).
    if reading is below 12.50, mahinang-mahina na po ang charging ng alternator niyo.
    Thanks po sa mga reply...
    Additional symptom po ulit... dashboard panel lights also dim when aircon is turned on...
    Quote Originally Posted by randyV View Post
    That's pretty much the effect if the voltage of the electrical system drops.
    Check if the battery is good.
    Check if the connection to the battery is good or loose.
    Jan 2008
    Is your car diesel powered? (brake boost is by vacuum pump at the tail of alternator)
    Possible causes:
    Imprope alternator belt tension, worn alternator belt, weak alternator, non-functioning AC idle-up mechanism, weak engine power (any cause).
    Quote Originally Posted by youngrider View Post
    Possible causes:
    Di yan. Sentra ECCS e.
    Possible causes:
    From his profile, he drives this car: Nissan Sentra ECCS SS 1992 A/T
    Jan 2008
    Sentra ECCS...Sorry, I failed to notice it.
    I'm wondering, what is the idle-up mechanism of this car when AC is on, vacuum assisted, electronic spark advance with IAC valve activation.
    Suggested order of inspection.
    1. Battery connections and battery
    2. Alternator belt
    3. Alternator
    4. Idle-up mechanism (is idle 750 RPM when AC is on)
    5. ?
    6. ?
    Jan 2009
    Is the battery indicator on the dashboard lit up?
    Almost the same set of symptoms happened to our ECCS a long time ago. 2 days later, it will no longer start due to a dead battery. We later found out that the alternator brushes were already worn out and it was no longer charging the battery.
    Jan 2010
    insufficient ang supply for quick check,, start your engine , while running remove the battery terminal & observed the engine sound. at dapat ay still running parin at pag namatay si engine! si alternator ang salaring!
    Apr 2009
    Just be very careful. Removing the negative terminal from the battery pole will do just fine for a quick check.
    Jan 2009
    Quote Originally Posted by billnomoney View Post
    Not advisable on cars with ECMs, which the Sentra ECCS obviously has. Doing so may introduce electrical surges and could cause more damage. Much more if indeed the alternator or RR is defective and is sending out unregulated and/or noisy electricity.
    Think of the battery as one giant capacitor.
    Beyond the hands of a good electrician, the Nissan CONSULT should be able to tell you if the charging system is out of spec.
    Sep 2009
    Alternator or battery problem.
    maybe you need a good grounding in your car. put a grounding kit just search it on how to hook it up. hth..
    Jun 2010
    pa add ako din nag dideam yung handbrake light,door open light(yun nga ba yun). nad dideam sya parang signal light pero hindi mo masyado halata kasi onting deam lang mine is nissan vanette. balak ko sana mag add ng grounding kit. puro bulok na kasi eh
Low RPM with headlights on and other problems...
