Results 1 to 17 of 17
    Jul 2004
    hello tsikoteers...
    i'm nebie here. may maybe you can help me sa problema ko sa akin revo,
    lately kasi napansin ko parang ang taas ng idle ng sasakyan ko, paano ko ba iadjust yung minor nya, puede ko bang i-diy ko lang ang adjustment nito.
    it's a 2001 revo dlx model.
    tia...
    You can, if you can find the idle screw in your carb (is this a carb model?). How high is your rpm?
    IMO, if the fuel consumption is still the same,I would not touch it...
    though check the cables if it returns properly...
    Jul 2004
    rion/afrasay,
    sir, thanks sa reply. it's an efi. i'll bring it na lang sa shop for check-up i'm afraid baka lumaki pa problema ko.
    thanks.
    Nov 2003
    near your tb there should be an adjustment knob. just turn it to fix the idle speed.
    hindi po efi ang revo diesel...
    meron screw na adjust para sa aircon idling, try ninyo observe engine bay, pag nag-on/off yung compressor, meron gagalaw na mechanism near the fuel filter.. andun po yung screw na ina-adjust..
    Jun 2006
    when was your last pms (change oil, oil filters, air filters, pollen filters, etc...) maybe is already due for service, if so have it also check the idle and timing of your car...
    regardless of where you service your vehicle they'll be happy to do it for you with no extra charge...
    go go go... fire in the hole!!!:fart1:
    Jul 2004
    thanks sa lahat who responded on this query.
    okay na po yung idling ng revo ko, i have it overhauled ( yung efi ) grabe ng
    dumi, ang sabi nung mekaniko yung iscv daw kailangan ng palitan, pero since wala pa kong pangpalit ginawan nya muna ng paraan.
    ang tanong ko na lang saan ako makakabili nung iscv bukod sa kasa baka may kakilala kayong tindahan na puede kung puntahan.
    this site is really a great help.....thanks.
    Jul 2004
    thanks to all who responded on my query.
    i haved it checked by a mechanic, kailangan daw palitan yung iscv ko.
    saan ako makakabili nung iscv bukod sa kasa?
    thanks..
    sorry wrong post.
    May 2005
    Quote Originally Posted by paopao View Post
    thanks..
    Bro.paopao..what is ISCV?
    Jul 2006
    I think it's idle stabilization control valve
    Just a guess
    Aug 2004
    my guess would be Idle Speed Control Valve...
    try mo magcanvass sa toyota casa....tapos kopyahin mo yung part number...tapos punta ka ng ichiban sa banawe or sa cresta motors (tapat ng AToys) sa west avenue....or any suking toyota parts autosupply store....dun mo ipahanap yung part na yun with the part number.
    HTH
    Jul 2004
    sirs,
    ISCV - Idle Speed Control Valve
    I'll take your advice sir wildthing, tawag ako sa toyota dito sa cavite.
    salamat po sa inyo ulit.........
    Jul 2004
    katatawag ko lang sa toyota, grabe pala price nito, i was quoted P15,226 for the part...
    Nov 2003
    ganyan talaga presyo kapag sensor...
idle inquiry
