Results 1 to 16 of 16
    Nov 2006
    Thanks for your replies. The MIL lighting up and the erratic idling only happens during cold starts but disappears after the engine has warmed up. I've been reading up on articles in the internet and it seems it is a common problem with CR-Vs in the U.S.
    Just in case the IACV needs to be replaced, does Speedy Fix keep IACVs in stock? How long does it take to clean and test it or have it replaced (so I can re-arrange my work schedule)? Thanks.
    Nov 2003
    nope, we don't keep them in stock. we will probably have to order from honda also. you can also bring your own pero i wouldn't suggest it until after you have had it cleaned. normally cleaning takes around 4-5 hours.
    did honda give you the mil code (in generic obd2 Pxxxx code)? could you post it here in the forum? please note that a MIL does not necessary mean a failed sensor or component but rather circuit problem. (pansinin nyo karamihan trouble codes ay nagsasabing **** circuit failure or problem)
    Sep 2004
    I'm not too sure, but in case sira nga talaga ang IACV ng CR-V mo, maybe you can try Toyota's IACV. Pwede rin daw, according to my mechanic here sa Commonwealth. Mas mura daw kasi, kung budget mode ka.
    Nov 2006
    what would be the effect if the two hoses (on the IACV) were put in differently?
    i mean, there are 2 hoses that's connected to it, right?
    what if baligtad ang pagkaka-kabit? yung dapat na nasa kanan napunta sa kaliwa,
    yung dapat na nasa kaliwa naikabit sa kanan?
    Nov 2003
    xonx, how's the car? hope di narin bumalik yung mil.
    Nov 2006
    Hi Migz, two days after, no problems so far. The idle is perfect and the MIL has not made an appearance.
    My beef with Honda is that when I asked the service advisor specifically if they took out the IACV and cleaned it, they said they did and that the error code still persisted so I need to replace the IACV. But when your crew took it out and showed me all that carbon build-up (more like soot) in the IACV as well as the problem with the throttle body, the service advisor obviously was not being totally honest with me, to say the least. And yeah, thinking about it, they were kind of hazy about the particular MIL code too.
    One thing I can say is that Speedy Fix has gained a new customer and Honda has lost a once loyal one. Kudos to you and your crew. For sure, you'll be seeing more of me (well, hopefully not that much, only on my car's PMS!).
    BTW, my staff will be sending you our request for quotation for the fleet maintenance agreement within the week.
Idle Air Control Valve
