Results 1 to 7 of 7
    anong idle nang focus?
    Alam ko medyo mataas ang idle nung sa akin 1.2 / 1k rpm... kaya malakas FC ko eh
    Ano ba ang normal? Ano ang dapat gawin ko dito?
    i think all car's idling is standard.... around 800-900 rpm, with aircon on.
    pag idling, first thing to do is to have the throttle body cleaned.
    Feb 2009
    Quote Originally Posted by CLAVEL3699 View Post
    your idle speed is controlled by the pcm. the average idle speed for four cylinder engines is 750 +/- 50 rpm in neutral for manual transmission equipped cars and around 700 +/- 50 rpm in drive for automatic transmissions. if the throttle body or the idle air control is dirty, the rpm drops below specs. since your idle speed is higher as per your post, check if the malfunction indicator is lit with the engine running and check the coolant temperature sensor if it is giving the correct signal back to the pcm
    Normal ang lahat nang signal.
    San makita yung coolant temperature sensor
    Feb 2009
    what year is your focus and what engine family is it?
    07 hatchback
    Feb 2009
    07 hatchback
    engine family like:
    4DR5O
    2TZFE
    3SGTE
    KA24
    GA16DE
idle
