Results 1 to 10 of 20
June 25th, 2005 03:54 AM #1
Tanong ko lang kung bakit pagka start malamig ang makina (honda vti 96), ragnerebuloyon at binitiwan ang gas pedal, bumababa ang rpm nya sa almost 400rpm at ang bagal niyang magstabilized uli sa 900rpm mga almost 20 secs pero hindi naman nagagatog o namamatay ang makina. Pero pag mainit na makina pagbitiw mo sa gas pedal bababa lang sandali ang rpm tapos balik na kaagad sa 900rpm. Ano kaya magandang gawin para maging mabilis ang pag pickup ang rpm pag malamig pa makina or this is normal lang? T.Y po
- Oct 2004
- 278
June 26th, 2005 12:24 PM #3Originally Posted by EssB
p.s. sa mga magrerecommend pwede sabi na rin ng way. thank you
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 27th, 2005 10:53 AM #4iacv cleaning along with the tb and intake manifold should do the trick...
June 27th, 2005 09:27 PM #5Originally Posted by speedyfix
- Nov 2003
- 3,849
June 27th, 2005 10:41 PM #6well, we can do it for you... call the number at my sig for directions and pricing.
June 28th, 2005 12:19 AM #7Originally Posted by raine
nakakita din ako ng ganito ,,parang tao na na inaatake ng HIKA ,,,,parang kinakapos ..pero d naman namamatay ang engine
- Nov 2003
- 3,849
June 28th, 2005 06:58 PM #9Originally Posted by speedyfix
hehehe ..so sir what is the real problem ...
is it the IACV?
BTW ...the ride nga pala is HYUNDAI ACCENT
- Nov 2003
- 3,849
June 29th, 2005 12:55 AM #10probably yun nga pero no way of being sure unless the car can be checked by a mechanic.
high idle RPM at engine start
