Results 1 to 10 of 14
September 11th, 2004 02:03 PM #1
tanong ko lang kung anong ideal na rpm setting kung idle for a mitsu pizzapie 97?
September 11th, 2004 02:46 PM #2
just below 1000rpm (around 700-900) dapat ang ideal (with AC on na yan).
- Sep 2004
- 24
September 11th, 2004 05:36 PM #4
mgbrillo,
Pre is your ride a GLXi? if it is then we have the same ride and this has been my RPM at idle
on cold-start (engine hasn't reached ideal temp and AC off) - 1200 RPM (note:this should go down gradually to 800 RPM within a few seconds)
When engine has reached ideal temp and A/C off - 800 RPM
Engine reached ideal temp and A/C on - 900-1000 RPM
If you're experiencing drastic dropping idle once the A/C turns on, there might be a problem with your servo or you might need to have it cleaned together with your throttle body. Throttle body cleaning solve my problem.
HTH.
September 17th, 2004 02:27 AM #5
It's a pizzapie 97 GL lang po.
Currently, idle RPM on start is 800-900 then goes to 1000- 1100(a/c turned on). okey lang ba ito? Paano ang Gas consumption if i have these figures when the car is idle? Thanks for the input guys..
September 17th, 2004 08:20 AM #6Originally posted by mgbrillo
IMO yung idle mo on start is okay na. Kung gusto mo ipababa mo ng one notch lower ang idle mo, then observe. Pero sa tingin ko oks na yang idle mo eh.
My 2 cents.
- Nov 2003
- 190
September 17th, 2004 08:28 AM #7Originally posted by mgbrillo
September 17th, 2004 10:57 AM #8
I was observing it just today.. mga 1000 nga pag idle with a/c on. pag walang a/c.. it drops to 900 then slowly goes up to 1000. Again, if i turned on a/c it drops to 900 then eventually stays at 1000.
Ako, newbie sa auto.. so I thank you guys for the inputs. if the above case it normal.. then I'd stick with the setting. if not, and if lowering it a bit would matter concerning is fuel consumption then the better.
September 17th, 2004 11:13 AM #9
yung unang nabanggit ko na 1000-1100 was just an estimation, that's why I observed it kanina.. para malaman ko yung saktong values.
September 17th, 2004 01:08 PM #10
yes sir, tama yung observation mo. kasi pag naka-on ang a/c e dagdag load yun sa makina. thus, hahabulin ng engine rpm yung idle para hindi siya mang nginig.
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
