Results 1 to 10 of 16
October 23rd, 2004 01:43 PM #1
http://motortrend.com/features/consu...gen/index.html
I like how they compared the hydrogen initiative support of politicians to baby-kissing.
But seriously, reading that kinda makes you realize how far other alternative technologies have progressed while big name companies have been pouring billions into hydrogen research.
October 24th, 2004 11:01 AM #2
yeah, it always sounded like it was tough to get off the ground. i thought the biggest obstacles to it were infrastructure (pipelines?), safety, and onboard storage, in that order.
October 24th, 2004 11:42 AM #3
people in the know are not very keen on hydrogen because the use of it in vehicles is not really a solution to the time when the oil wells all dry out (in about 30 years time). using hydrogen simply transfers the burden of energy production from one place (the gasoline or diesel engine in your car) to another (the power plants that will provide the tremendous amounts of electricity needed to separate hydrogen from H2O, to liquify it and then to store it). and hydrogen powered internal combustion engines are also not that efficient.
electric cars are more promissing than hydrogen powered cars. the reason is simple. the best electric motors run at almost 99% efficiency while internal combustion engines theoretically can only go as high as 37%. so why double the losses (produce hydrogen using a nuclear power plant running at 47%, then produce mechanical power in the car using an internal combustion engine) when you can eliminate most of the losses in the car by using batteries and electric motors.
one possible use of hydrogen is in electric cells that power electric motors, but that too is too heavy and by its weight alone will negate whatever increase in efficiency provided by the electric motors.
in the end, i believe, the electric motor-battery combination will prevail over the hydrogen-internal combustion engine or the hydrogen power cell-electric motors. reason is simple, they already have plastic batteries that can store more energy that ordinary lead acid battery, and it will not be long before they can put as much electric energy in a battery the size of a gas tank and still give the same mileage as 1 tank of 95 octane.
although this solution still does not get away from the problem stated in the first pharagraph above (transferring burden of energy production), if the fusion reactors they are working on will work then that is no longer an issue. the world can have all the energy it needs and not be afraid of ever running out.
October 24th, 2004 01:23 PM #4
Fusion is so far away at this point it's not funny. Because of the expense of Fusion research, a lot of governments and big business have been turned off by it.
Galing mo, sir yebo... that's the same argument I have against the so-called hydrogen-powered vehicles made by local inventors... you need so much battery power to run an electrolysis machine that if you had enough battery power to make it feasible, you could run the car off the batteries themselves.
I particularly like the idea of ultracapacitors... and I have seen in the past few years how rechargeable batteries have gone from 15-minute wonders to powerhouses that outlast disposables by up to ten or twenty times on one charge cycle...
October 24th, 2004 09:35 PM #5
what's the news about this fusion reactor they are building in France? di pa yata tapos eh, but they are putting billions into it. sana umandar.
talking about that fool inventor na na-feature pa sa tv, hehehe! hydrogen generator powered by a car battery and alternator! and he claims the alternator alone can produce enough power to produce enough hydrogen which then powers the engine! here we go again, PERPETUAL MOTION MACHINES! those filipino "inventors" should know that the laws of physics and chemistry were made by God and not by men, and therefore can not be changed by their so-called "genius". mga kamag-anak ba ni erap mga yan at lahat ng laws e akala nila pwede i-repeal??? (remember the erap joke about the law of supply and demand hehehe!)
October 24th, 2004 09:54 PM #6
i feel like im in school again.
in my opinion, methane can be an alternatives.
since every living creature produces it (fart power).well atleast bacteria products.
they have to be serious about it. methane is one of green house gasses that add to the reductions of ozone.
October 24th, 2004 11:14 PM #7Originally posted by iqaruzz
the biggest problem with NG is probably distribution...but if automakers and governments are committed for the long term, i don't see how this wouldn't happen.
edit: i'm actually talking about compressed and liquefied natural gas (CNG and LNG), of which methane is actually an emission and a component.Last edited by empy; October 24th, 2004 at 11:19 PM.
October 25th, 2004 12:38 AM #8
Ok lets say in 30 years oil wells dries out... what alternatives would be feasible here in RP? I can't see an electric/battery powered car here because of the flood problem.
October 25th, 2004 01:26 AM #9
Any flood that can kill a sealed electric motor would likely kill a gasoline motor, too... so that's not a problem.
The most realistic and near-term solution would be an LPG or CNG powered hybrid-electric. There is already a limited distribution infrastructure in place for LPG.
As for Fusion, who knows? It will likely take many years more and probably another trillion (that's right... 1,000,000,000,000) dollars worth of research to even make it feasible. It's like hydrogen research per se... there are too many breakthroughs needed to make it work... it will be a long time coming...
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
