Results 1 to 4 of 4
    Nov 2011
    Hi,
    I bought a brand new VIOS 1.3 M/T last December 2011. As a freebie, finull tank ng Toyota ang car ko with Petron unleaded. They say Shell unleaded is better than Toyota but I cannot switch because some says that switching gas brand would affect my engine's performance. How true is this? Does switching from one brand to another will really affect my engine.
    Thank you in advance.
    Jennivivs
    May 2010
    NOT ENTIRELY TRUE. What true is the location of gas stations (if magkakatabi sila) should be free from flooding throughout.
    Not really true. Just fill up on trusted gas stations that sells clean gasoline.
    Feb 2009
    today's cars are able to adapt and learn. it is smart enough to adapt to changes in engine wear and tear, loose compression, reduced tire circumference from wear and of course, the rated octane number of the fuel. as long as the gasoline is clean and not contaminated, it should be okay. you probably have heard about flex fuel systems. the question about your myth is like that of the "tikbalang" and "kulam"
HOW TRUE? Stick to one gas brand.
