Results 1 to 20 of 20
    Jul 2012
    hi guys,
    just would like to ask what is the EASIEST/FASTEST way to suck/sip fuel from a vios 2010 manual 1300cc
    I have thought of ways but I am not so sure if this will work or I might damage some hoses/sensors.
    1. go under the vehicle, find the fuel tank, find the the hose which leads to the tank, I think there is a small hole which we can put a hose which sucks fuel.
    2. pop the hood, find the fuel filter, (i actually dont know where it is), find the hose which goes to the engine, then disconnect the hose, start the engine and start sipping fuel.
    3. lift the back seat, open the fuel lid, but we tried this yesterday, we cannot seem to open it.
    Do you guys have tried this before? hope you can help me.
    May 2004
    wala bang drain plug yung fuel tank? medjo mahirap din kasi ang alam ko may separator yung mga fuel tank... kung talagang all gas i think you need to pull down yung gas tank because of the seaparator ng mga tank.. ...
    Jul 2012
    nope, no drain plug.
    actually just need 15 - 20 liters.
    Aug 2004
    Best to pull down the tank or find the drain plug underneath. If you can't find it, only other way is to pull out the fuel pump assembly under the rear seat and insert a hose to siphon the gas. But this will make your cabin smell of gasoline fumes.
    bakit ka kukuha ng gas sa tank? sorry ha. na curious lang ako.
    Jun 2007
    ^^ about 20 liters ... around P1000 yan
    Dec 2009
    open the line before the fuel rail, rubber hose yun, then get a container, itutuok mu sa container then ask somebody to key it to ignition, sisirit yung fuel sa container.. just be careful with the gasoline... baka masunog kotse mo...
    Sep 2005
    hindi ba pwede don sa may gas lid? saksakan nang hose tapos sipsipin?
    Jul 2012
    Quote Originally Posted by miko101130 View Post
    Did you mean by the fuel rail, is the rubber hose going to the fuel filter or going to the engine?
    I am not so sure where that is. Do you have a diagram on where that "rubber hose" is?
    Jul 2012
    This would be best if I have time and the personnel to do it. I just have my driver and me to do this.
    Yes, I have seen the fuel pump assemble beneath the rear seat. What I did was take out the cover which is covered by black sticky stuff. Then a steel cover with 3 hoses in it. I think 1 is for the fuel gauge sensor.
    But it is so hard to take out that steel cover.
    Jul 2012
    this is the first step i did, but no avail since madaming pasikot pasikot and may mga "blockages" pa papunta sa fuel tank.
    Quote Originally Posted by robot.sonic View Post
    Papaihi?
    +1
    magkaiba ba yung gas na galing sa kotse kesa sa gas station? wala lang. curious lang din.
    TS Bakit nga ba? ano bang meron?
    baka diesel nailagay.
    Oo nga bakit?
    Kung ang dahilan ay ibebenta mo na yung kotse at sulitin yung natitirang gas dun, ang cheap mo naman. Pero kung dahil may halong tubig/diesel nailagay, bakit ikaw gagawa? Pagawin mo yung may kasalanan.
    Jul 2012
    Oo nga bakit?
    tama! imposible nalagyan yan ng diesel, wala ever na diesel na vios na ginawa at sa dami dami ng vios ikaw na pinaka malas na nalagyan ng diesel kung sakali...
    wag kayo suggest ng suggest at di nyo naman alam ang tunay na balak ng treadStarter... baka sa kasamaaan pa gamitin yan...
    ingat ingat lang
    Quote Originally Posted by HonestTruth View Post
    ingat ingat lang
    bakit po impossible? hindi ba kakasya ang filler hose tip sa opening?
    Dapat full drain.
    Balak nya 15-20L lang eh......
    may mga kakilala ako, may gamit sila na company car so unli ang gas nito. ginagawa nila pag full tank hinihigop then salin sa ibang kotse..
how to suck fuel from vios 2010
