Results 1 to 10 of 10
    gud day...is it enough to shower the engine with water?
    panu po maalis ung mga itim itim sa mga gilid gilid po?
    ung alikabok po maging mud?
    bukod po sa airfilter and battery, anu pa po ba mga dapat takpan po?
    any detergent or degreaser can be use?
    anu po ba tamang procedure?
    nakakainis po kc ung mga carwash dito samen...2hrs ang pilahan...inde pa pulido ang linis, sometimes spots are missed...
    help po mga gurus
    tnx ng marame
    altis
    Mar 2007
    all i do is cover up the intake manifold. yun lang. pero kung may distributor ka (yung old type) kasi yung akin electronic lahat. wala nang dist. so intake lang tinatakpan ko. tsaka warm up your engine first. not totally hot. just warm it up. 1 min is enough. para lang may capability siya na mag evaporate ng water if you wet it. delikado na kasi if malamig makina mo baka magkaroon ng stagnant water dyan hehe
    well, this is just for me. i even tried it on a hot engine. smokes all over. but ok parin hehe
    Feb 2005
    I mix up a soap solution and put it in one of those bottles with a spray(er?) head attachment. After putting a rag over the alternator, distributor and over where the HT wires go into the valve cover, I spray the solution liberally all over the engine bay. I then use a sponge that i dip into a bucket of water to rinse off and clean out whatever I can reach.
    naku wag po i warm up kung engine wash... as much as possible keep it cold kasi pagbiglang masalpakan ng cold water yung hot engine, baka may magcrack (worst case) or may madamay na component ng engine.
    i use several products for engine wash, bug and tar remover for painted areas, joy with water for plastic areas, and yung pang garden na spray (yung pump to create pressure thingy :bwahaha, degreaser minsan kung garapal na yung putik.
    i remove the battery and the cold intake para hindi mahirap maneuver sa ilalim. then cover the alternator, intake, and distributor.
    una, i clean the painted areas with plain water then do bug and tar remover kung may stains. for the plastic areas, yung joy with water and gamitan ng old toothbrush para malinis ng mabuti. yung metal parts naman, kung garapal na yung dumi... degreaser na pero kung hindi pa naman, ok lang na joy pa rin gamitin.
    sobrang nakakapagod lang and ubos oras pero after,,, sulit naman pagod
    hth
    wag sabon na powder or bar, they usually turnes to white when dried. mas maganda yung liquid soap, walang residues...
    ok lng po kung pati ung top engine block (plastic cover removed; mababasa na po ung mga spark plugs wires) po ng altis ibrush ng toothbrush with soap po?
    tnx po sa mga advice...i really need them po...novice po kase bout sa kotse and new tsikoteer
how to diy engine wash?
