There's a lot of possibilities that cause this kind of problem. Some possible reason would be bad wiring, worn starter, bad battery, problem on the charging system. But mostly this is due to a bad starter. But before concluding the problem, you might want to check your battery and cables. You can check and diagnose those parts and try to repair it. However, I would still recommend visiting your trusted car shop to have it diagnosed for possible repair. Doing this will avoid a misdiagnosed problem that could worsen your car's condition and ruin it completely. Hope this helps!
