Results 1 to 4 of 4
    mga bossing,
    here's my problem...ayaw po magstart ng auto ko...situation is nagstart sya tapos biglang namatay tapos since then ayaw na nya magstart...called the mechanic from Total and they check ok naman daw..malakas ang redondo at ok din battery (try nila iseries un auto kasi)...so they told me malamang electrical ang problem so they called in another mechanic..check nya ignition coil daw ang problem...pinalitan ignition coil pero ayaw pa din magstart...then check nila yun computer box tapos nun inopen nila parang meron burned na part....
    ano po bang possible problem?? i asked some people and they told me malabo daw na sa box yun unless mabasa un box dun lang nasisira yun....
    car is automatic 93 model honda civic esi...please help...
    kailangan mo ng mahusay na mechanic jan .
    si speedyfix well versed sa mga honda cars .
    Sep 2004
    Pupuwedeng computer box, especially kung matanda na yung kotse. Over at hondaclub.com.ph, may thread dun about capacitors sa ECU box na nag-leak at nag-short, leading to no-start scenarios.
    See this thread...http://s3.zetaboards.com/HCP/forum/21301/2/
    I'm also inclined to think na ECU mo nga ang salarin.
    Sep 2006
    efi ba EG mo sir?nag check engine ba? kapaparepair ko lang kasi last month ECU ko may nirefer saken si simplicity na mechanic baka makatulong.
Honda Civic ESI 93 model not starting
