Results 1 to 10 of 22
- Aug 2005
- 183
March 12th, 2008 02:02 PM #1need advice lang po....yung radiator ko always needs overhauling every 2 to 3 months....alam ko na pag kelangan....the engine temperature rises to 3/4ths pag may bara na yung rad....ang bara niya is latak and not kalawang...the problem ko is nagpalit na ko ng rad (evercool) ganun pa din ang situation...by the way, i only put minimal or no coolant(advice sa kin ng naglilinis ng rad)....what should i do?thanks
March 12th, 2008 02:29 PM #2
sir, i think the coolant is there for a reason. para hindi magboil kagad yung water regulation sa engine. also try putting distilled water para wala masyado corrotions na mangyari sa radiator mo. kalokohan yung 2-3 months ka overhaul ng rad...
i think, the best is dalin mo kay speedyfix para diagnose ng mabuti. sobrang ok sila gumawa. recommended ng mga tsikoteers.
March 12th, 2008 03:50 PM #3
also check this link baka makatulong sa problem mo, http://tsikot.yehey.com/forums/showthread.php?t=46013
March 12th, 2008 04:34 PM #4
I think may langis na humahalo sa radiator mo. Kulay putik ba? You may have a warped cylinder head gasket.
March 13th, 2008 04:21 PM #5
mukhang sabog ata yung nag lilinis na yun ha! lolz! man, pag walang Coolant, mas lalong kakalawangin ang Cooling System (specially pag metal type pa ang Radiator, and also pag Cast Iron ang Block) but in your case, Aluminum Block ang makina ng Civic mo, but having only Water on your cooling system wont really protect your engine from over heating. coz Water has a lower Boiling Point.
anywayz, before doing anything else.. make sure na may Thermostat ang makina mo. and pag wala.. yun ang problema ng erratic temperature ng kotse mo. and also, make sure that they purge all of the air out of the Cooling System.
aite, peace.
- Jan 2008
- 4,726
March 13th, 2008 07:59 PM #6"chemical coolants" only destroy your radiator, water itself is a natural coolant... i've experienced this several times na yung radiator ko eh nasira using 100% coolant and even at 50/50 coolant-water ratio still my radiator's solder points get corroded...,i have a kia besta before, madalas sumabog or magkatulo radiator kaya madalas tapon lang yung coolant ko mahal pa naman.. pag binuksan mo yung radiator eh puro corroded na yung loob.. sabi nung nag ooverhaul ganun daw talaga effect ng coolant, kaya ayun after 3rd repair plain water na lang gamit ko. napansin ko mas ok ginamit ko pa yung van ng mga 2years hanggang sa ibenta ko hindi na nagloloko radiator ko... kya sa iba kong rides plain water na lang talaga... still the best coolant to your car is water specifically yung distilled para mas malinis...kahit dun sa coolant resevoir water lang din nilalagay ko...
if meron latak yung tubig ng rad mo possible may humahalong langis dyan coming from the engine.. some cars especially A/T transmission have cooling tubes going to the lower portion of the radiator, this serves as the ATF cooler for the transmission... kung wala naman eh possible sa engine mo galing yun latak... yung oil when mixed with water under high temp then passes thru your water pump blades, magkakaron talaga ng parang latak (parang chocolate milk shake na napanis...)
Tsikot Member Rank 5
- Nov 2003
- 3,849
March 16th, 2008 11:51 AM #7coolant is anti rust and acts as a lubricant to all of the components like the waterpump etc.
i don't know how people can think it is not good for the cooling system when all cars come standard with it.
- Sep 2007
- 110
March 17th, 2008 10:00 PM #8+ 1000 kay sir speedyfix. sana lahat ng radiator ng sasakyan ay sira dahil almost every car are using coolant sa radiator nila. i think we should also consider the quality and the wear and tear of the car's radiator not the coolant itself that should be blamed of. coolant is there to protect not to destroy.. just my 2 centavo.. peace
March 17th, 2008 10:19 PM #9
pansin ko karamihan sa mga nag overhaul o gumagawa ng radiator sinasabi na kaya nagbabara ang radiator dahil cause daw nito ay coolant.. pero dahil sa mga nabasa ko dito sa tsikot and mga feedbacks about coolant naging malinaw sa kin ang lahat..
- Jan 2008
- 4,726
March 18th, 2008 07:27 PM #10that's right sir... most likely a car using pure coolant like prestone and other brands will definitely have shorter radiator life compared to others using pure distilled water only... alam ko din kasi madalas din masira radiator ko nung gumagamit pa ako ng coolant.. yan din sabi ng nag overhaul sa akin, lahat daw ng ginagawa nya radiator eh grabe na ang corrosion caused by coolant..
coolants are recommended for countries that have season of extreme low temperatures (like japan, korea) wherein coolant also serves as anti freeze..
my first ride is a besta van, since i know this van is prone to overheating , i used 100% coolant kasi sabi sa ads eh mas magaling kesa tubig, after 2years my radiator needs a complete overhaul, again i refilled with 100% coolant, same thing happened... i also noticed na yung radiator ko eh may formation ng latak... that is when i decided to use back to basics 100% distilled water.. ayun for the next 3 years na ginamit until i benta ko na yung van ko eh walang reklamo yung radiator...
my 2nd ride is a kia carnival, same din, i immediately removed yung coolant and changed to distilled water... may formation na din ng latak before i changed.. since na pinalitan ko ng distilled wala na yung latak..
we also bought a 2nd hand L300 exceed (local) naka coolant din napansin ko pa nga pag medyo high speed say 100kph eh medyo tumataas ang temp to 1/2, same manifestations daming latak sa loob ng coolant reservoir, nilinis ko agad then change to 100% distilled water.. as of now walang overheating.. kahit 120kph still 1/4 lang ang temp
My Ford SYNC just updated itself. Anyone here knows what was updated?
2023 Ford Everest Owners Thread
