Results 1 to 20 of 22
    did you use distilled water or just ordinary tap water?? if tap water possible you have use hard water kaya ganun... tapos may halo pa coolant
    +1 dito.. as much as possible try using distilled water rather than tap water kasi dami impurities ng tap water.
    Nov 2003
    if laging may latak you might need to use the lavramon machine.
    Aug 2005
    mr .speedyfix, ano po yung lavramon machine?what does it do?
    May 2004
    Quote Originally Posted by r_delro View Post
    Lavramon parang Dialysis ng cooling system... You must remove your Termostat before doing a Lavramon...
    Regarding naman sa coolant or no coolant sa akin same lang as long as you use distilled water... All our cars don't use coolant and so far so good... Before sa corona ko I use coolant plus distilled water 50/50 ratio... mga 1 year lang life span ng Radiator ko... BTW I use evercool radiator... but when replaced with distilled lang tumagal radiator ko for 3 years until na benta ko... Pero tama sila coolant lubricate your water pump... kasi nasira water pump ko nung nag distilled lang ako... hehehe... pero after napalitan ok na...
    Aug 2005
    san available yung lavramon machine at magkano kaya abutin nun?thanks
    Nov 2003
    yup parang dialysis machine. sila autoteknika have it.
honda civic 97 cooling system problem
