Results 1 to 10 of 14
- Jan 2011
- 11
January 6th, 2011 01:40 AM #1help nman po hirap n po humatak yung mit adventure ko diesel 2003 mdl. kakachange oil ko lng po almost a month. nilinis ko n rin po yung filter s machine. nilinis ko n rin yung fuel filter. ano po kya problem ng sasakyan ko? para po kcng galit n galit yung maakina pag nag accelarate ako? parang puro gas lng mahina humatak. tnx po
- Sep 2006
- 1,335
January 6th, 2011 10:23 AM #2
- Nov 2009
- 456
January 6th, 2011 10:38 AM #3
- Jan 2011
- 11
- Jan 2011
- 11
January 6th, 2011 11:54 AM #5opo manual transmission po cya..... pero mabilis p rin po ang takbo kaso po hindi n tulad ng dati na pag nag accelerate hatak kgad eh...
January 6th, 2011 12:29 PM #6
- Jan 2011
- 11
January 6th, 2011 02:30 PM #7wala pang pinapalitan s clutch. meron po bang symtoms yun ganun para malaman kung s clutch n nga ang problem? tnx....
January 6th, 2011 02:43 PM #8
Your observation alone that your Adventure does not fully accelerate when you shift gears is already a symptom of your clutch wearing out. Try to apply handbrake on your ride then depress your clutch, shift to a gear then slowly releasing the clutch pedal, if the engine does not stall, and continues it's operation then time to visit your mechanic and have your clutch system pulled down.
- Jan 2011
- 11
January 7th, 2011 07:41 AM #9
January 7th, 2011 08:12 AM #10
high idle RPM at engine start
