Results 51 to 60 of 150
September 23rd, 2007 11:31 AM #51
ive been using pertua for about 2 years now. i used superior engine treatment oil before, imported from australia, pero may kamahalan,. ok ang pertua, malakas ang hatak, medyo pino ang andar ng makina. is there really truth on its claim that its being used in apache choppers? matagal ko na nababasa yan but find it hard to believe.
Tsikot Member Rank 5
- Nov 2003
- 3,848
September 23rd, 2007 03:20 PM #52it's pretty good but we only use it as an assembly lube... not to mix with oil changes.
September 24th, 2007 10:24 AM #53
aba... so there's a chance that this really works? marami na tsikot members na nakagamit at nagsabi na maganda ang effect sa rides nila ah!
baka dapat may magtest talaga tulad ng ginawa sa khaos... para masettle once and for all: effective or not?
- Aug 2007
- 675
September 24th, 2007 11:46 AM #54
September 28th, 2007 06:53 AM #56
Tribotech ang pangalan nito sa U.S.
http://www.atechtt.com/tribotech.htm
- May 2004
- 102
September 28th, 2007 08:05 AM #57nasubuka ko ito ok naman. but may nakita ako na i could call "the best among the rest" since taob lahat sila dito. yun gamit ko ngayon ito yung true additive. hehe
- Sep 2007
- 215
September 28th, 2007 06:45 PM #58Pertua wholesale price is around 275 pesos ... suggested retail price is aroudn 320 - 350 ...
kung 400+ yan mahal yan ...
usually oil has no expiration dates and pertua is proven to be a very good lubricant ... basta be sure 3 motor oil and 1 pertua ... kasi usually most cars 3 1/2 liters pag change oil ...
if interested ... text me 09178999989
320 benta ko sa pertua ...
Banawe Auto Supply 7120115 regy
- Aug 2007
- 675
September 28th, 2007 08:17 PM #59
- Nov 2003
- 3,848
September 30th, 2007 02:24 PM #60assembly lube: what we use to coat the bearings of an engine while it is being reassembled due to an overhaul, etc.
byd seal5 dmi. that coolant tank is the same setup like in the fords. plastic coolant lines :twak2:...
BYD Philippines
