Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    is it ok to replace only the valve seal?
    my engine is still running great(strong and quite) and still looks great because of proper maintenance. the only problem is that since this February it started emitting white smoke once in a while, while driving. but now its continuous.
    i'm planning to have a top overhaul, but just replacing the valve seal. i don't want it to be brought to a machine shop. because it still runs great.
    any suggestions?
    thanks
    What is the smell of your exhaust? Oil consumption?
    If the car still runs ok wag mo na galawin.
    On your next tune up readjust valve clearance and tanong mo kung pwede na isama and palit ng valve seal.
    sir when it is at idle there is no visible smoke naman. it only appears when the car starts to move or when it reaches 2000rpm. when i'm running for about 80kph the smoke starts to enter the trunk then into the cabin. it smells like burnt oil. my car is a sentra lec ps. i'll try that sir thanks.
    Jul 2003
    if it smells like burnt oil, you might need more than a change of the valve seals.
    check your oil level and see if it drops as you use the car over a week or month. if it does, the engine might be in need of overhaul. but you can do a compression test just to make sure of the condition of the internals. do not overhaul the engine unless it is necessary or is long overdue.
    the car is still performing great. it's still quite and still have power. so it didn't occur to me that it needed an overhaul. last month the oil level from the dip stick declined to about 1/8 or more so i've added some oil. up to now the decrease of oil is still not going more than 1/8 from the dip stick.
    how much is the compression test sir? is it available at servitek branches? i'll also try to have a test if its cheap.
    What is your mileage? Try o pull the dipstick while engine is running and observe the oil that spits out kung maliit na talsik or sumusuka. Check your tail pipe for wetness due to oil. Check your air filters if clogged the pistons has a tendency to suck oil because not much air is available. Magipon ipon ka na for overhaul for a top or general overhaul. Once you get white smoke at lower rpm means your piston rings/cylinder walls cannot hold compression for ideal combustion.
    it already has 170k. i've already checked if the oil spits at the dip stick, no spitting seen. the tailpipe is dry and powdery like. i've just replaced the air filter, spark plugs, fuel filter and oil filter this month. the only thing i've noticed is the spark plug being a little wet at its thread.
    Dry and wet compression test will verify whether its head or block overhaul or everything is still ok and within limits then no major work is needed.
    Jan 2008
    had the same exact problem first week of april...top overhaul was the solution...matitigas na valve seals...so they need to be replaced...
    that's in my ride's case...
    how much would the compression test cost?
Help on Top Overhaul
