Results 1 to 8 of 8
    May 2010
    NagpaTop overhaul ako ng 94 Lancer EL dahil may lumalabas na na water sa tambucho, may oil sa radiator and nagooverheat
    The price:
    valve seal - 1020.00
    cylinder head gasket - 950
    exhaust gasket - 850
    brake gasket - 380
    valve cover gasket - 580
    motor oil - 1120(280 each)
    oil filter - 580
    camshaft oil seal - 380
    cylinder head top resurface - 1200
    labor - 2500
    gas - 500
    Total: 10060
    Tinaga ba ako or not?
    Gusto ko sana malaman para malaman ko kung magpapagawa pako dito
    Thanks
    Apr 2010
    sir, much better if you'll go to auto parts shop and check for the prices of your parts needed for your car. ang top overhaul kase eh sa pagkakaalam ko eh hindi hihigit for 5k. yung sa tropa ko meron syang sariling talyer, and the cost of their top overhaul for gas engines ranges from 3500-4k, depende pa ata sa model ng kotse. eniwei, many gurus here will inform you kung tinataga ka nila. buti na lang hindi ka pa nag-go signal, hehe..
    mahal ang materyales, oil filter 580??usually less than 300 pesos lang ito. Hindi ka lang tinaga, you've been chopped into pieces
    Dec 2009
    Your not talking about casa quotation are you? Mahal naman yan sir, the L/O filter is very expensive PHP580? Ganito na lang sir, if you have time you can go to different auto parts and canvass it yourself. Better still look for another shop. Sa oil filter pa lang mahal na. HTH
    Jan 2008
    Okey na lang kung naayos naman ng mahusay yung sasakyan. Kung di mo pa nababayaran subukan mong humingi ng diskwento.
    Magdala ka lang ng mga goons baka itak naman ang abutin mo. Si hudas ata ang nakuha mong mekaniko kasi harap-harapan kung manloko.
    Pero baka naman puro primera klase talaga yung mga materiales na ginamit at master ang gumawa. Saka yung repair shop baka quality talaga. Kung ganyan ang sitwasyon eh sulit na yan.
    Yung refacing na yon, kasama na sana sa labor charge nila. Liha lang naman at babad sa soapy water solution ang gagawin nila dun.
    *TS
    hindi ko alam exactong price ng pyesa ng ride mo but to make a comparison i have a Mercedes benz 190e ang oil filter nya costs only 370-400php each, so i think tinaga ka at least for the oil filter
    sa Rapide ba yan?....
Tinaga ba ako?
