Results 1 to 6 of 6
November 25th, 2009 08:26 PM #1
hi mga tsikoteers!
just wanted to consult something about my car, corolla 1991. there's a tendency kasi na bigla na lang siya mamatay ng walang ano2x. the past few days wala akong biyahe na hindi ako namatayan.before after mamatayan, mabilis lang at start agad. sa ngayon matagal bago mapa-start.my redondo naman siya ayaw lang tumuloy.
sabi sakin ng electrician baka daw sa alarm kasi nacheck na niya yung ignition linings wala naman nakita problema?
sabi naman ng tatay ko baka may loose wirings daw?
pina-tune up ko na yung carburator at pinalitan na ng repair kit tapos nagpalit ako ng ignition coil yung nasa assembly ng distributor.
tulong naman guys!
TIA!
November 25th, 2009 09:14 PM #2
things to check:
- ht wire
- carb (may need overhaul or cleaning)
- fuel filter
- fuel pump
November 27th, 2009 08:44 PM #3
*1D4LV
-nag-undergo na ng tune up ang carb.
-the HT wire binalik ko yung stock nya kasi before gamit ko yung HTW ba sewa brand from nearby auto supply shop.
-the fuel filter was replaced 6months ago
yung fuel filter di ko pa nagagalaw.sir, yung fuel filter san banda makikita?
TIA!
November 27th, 2009 09:16 PM #4
ano ba ang makina mo 2e or 4af?
at any rate, it could be a sign of malfunctioning igniter. it can be found inside the distributor.
or it could be the canister valve. this can be found attached to the charcoal canister.
have then checked.
hth
November 28th, 2009 12:35 AM #5
Paki check mo rin ang spark plug mo baka mayroon diyan na palitin na at iyong gasoline line mo baka may singaw na iyong hose.
- Nov 2009
- 87
December 3rd, 2009 02:05 PM #6MY REPLY :
1. First and foremost Have your car be check for compression test. from the above I quote " sa ngayon matagal bago mapa-start.my redondo naman siya ayaw lang tumuloy". If it passed the said test go to my
number 2 advise.
2. Kindly check the electrically operated solenoid valve in the carb. Check the supply voltage. Bka eratic or nawawalan ng electrical supply kya nag ko closed ang solenoid at nawawalan ng fuel supply ang carb mo kaya namamatay.
3. Have your carburator be check by a competent automotive mechanic. I feel it needs to be overhauled to the most all metered holes and corresponding jets be blown with air compressor. Better buy na carburator repair kit.
Have U ever noticed that your car is emitting white smoke in it's tail pipe?
White smoke in the tail pipe is a sign of loose compression.
Eratic na po ba ang minor ng inyong sasakyan. Particularly kapag nag aircon na kyo tataas or bababa ang minor to the extent the engine will die down? Pabago bago na ang minor ng vehicle. This is 1 (one) sign of loose compression na po. H
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
